Cayenne headlight problems
Old Oct 18, 2013 | 01:37 PM
chopperdave's Avatar
chopperdave is infamous around these parts
I've recently bought a Cayenne Turbo and after a month or so the LH headlamp started to develop condensation inside the lens housing.
I took the headlamp unit out and dried it out (gently!) with a hairdryer and it worked fine.
After a couple of (very wet..!) weeks the problem came back. Same routine, I took the unit out and dried it with a hairdryer. Now the dipped/hi bi-xenon light, the cornering light and the additional hi beam have stopped working.
The sidelight and indicator are still working. It looks like (from the Owners Manual) there are 2 fuses indicating seperate 2 circuits. Both appear to be intact and not blown.
Before I spend some cash taking it to the dealers does anyone have any suggestions...???
Old Oct 20, 2013 | 09:44 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Either a crack in the housing or it's not sealing. My guess is crack.
Old Oct 22, 2013 | 08:05 AM
Dennis C's Avatar
Condensation is actually a common problem for Cayenne headlights, especially in humid climates. Porsche issued a TSB to correct this problem with the insertion of a desiccant material to absorb the moisture inside the headlight. My guess is that the reinstallation of the headlight brought up another issue, which also required a TSB - the headlight connection issue. Both items are a relatively easy fix.
Old Oct 23, 2013 | 03:18 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Now that your cornering lights stopped working, you have a bigger issue than finding out how the moisture got in there. If you have a Durametric, then I suggest you hook it up and look for error messages under the headlight modules. Record the errors, then try to clear them out. Then take it from there...
LiquidElephant
Aug 27, 2015 06:17 PM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
