Detailer's Domain now carries the Vac N Blow
We are pleased to announce that we now carry the Vac N Blow vacuum cleaners.
Here is a description: Metro Vac 'N' Blow This twin fan 4 peak horsepower vacuum is the most powerful car vacuum ever tested. It has an amazing 95" of water lift (the standard measure for a vacuum's efficiency). Compact, powerful, portable, it's heavy-duty lightweight all-steel body is only 17" long and 7" in diameter which makes it easy to handle. Use it off road, too, as a vacuum for cleaning around the house or yard, or as a blower to inflate rafts, air mattresses or blow away leaves. On road or off, Vac N BloŽ offers the versatility you need. It comes fully equipped with a wide range of attachments, so whether the job calls for power or precision, you'll have the right tool at hand. A 6 ft flexible hose plus two 20" extensions reach even the furthest corners. Other attachments include: an upholstery tool, dust brush, crevice tool, blower nozzle, air mattress inflator, shoulder strap plus 4 "detailing" attachments to get into tiny spaces. Vac'N Blo Features: - Construction: All Steel, Made in USA - Motor: 4.0 HP, 95" Lift - Volts: 120 V, 11 amps, 12 ft. Extension Cord - Decibels: 73-77 - Hose: 6 ft. Flexible Hose, (2) 20" Extensions - Filter: Reusable Dust Cloth Bag - Attachments: Upholstery Tool, Dust Brush, Crevice Tool, Blower Nozzle, Air Mattress Inflator, Shoulder Strap, 4) Mini "Detailing" Attachments. - Warranty: One Year Item ships only via UPS Ground Click here to purchase http://www.metrovacworld.com/grafx/l...acnblo_600.jpg |
better then going door to door there Phil ;)
good one!
| All times are GMT -6. The time now is 12:26 AM. |
