Meguiar's now available at Detailed Image
Detailed Image is proud to announce that we now carry the Meguiar's car care products. Meguiar's has a long history of making high quality car care products since the invention of the automobile. Their product line has expanded greatly over the years and they continue to impress us with top quality results. It is a family run business that is now in it's 4th generation inside the Meguiar's family and we are proud to work with them. Here are the Meguiar's products we have selected thus far:
Meguiar's Ultra-Cut Compound M105
Used by many top high end detailers, an extremely versatile cutting polish that has quick cutting action to tackle almost any imperfection. It has the most rare combination of strong cutting power that removes deeper imperfections while finishing down very smooth and glossy.
32 oz & 128 oz
Meguiar's Ultra Finishing Polish M205
Excellent finishing polish that removes any haze from the M105 and restores a vibrant gloss! Use a glaze, sealant or wax after to enhance the fresh shine.
32 oz & 128 oz
Meguiar's Speed Glaze M80
Removes light surface imperfections while adding tremendous gloss to the surface. Perfect step to do after more aggressive polishing and before applying a sealant or wax.
32 oz
Meguiar's Speed-Cut Compound M95
Very strong cutting power to remove the deepest surface imperfections. It's safe and easy to use, just follow up with a lighter polish like the M205.
32 oz
Meguiar's Quik Interior Detailer
Arguably the most versatile interior cleaning product ever made, one bottle cleans just about everything! Check out the product review on the Meguiar's Quik Interior Detailer from Todd at Esoteric Auto Detail.
16 oz
Meguiar's Ultimate Quik Detailer
Helps you clean, protect and enhance the surface gloss with one easy to use formula.
22 oz
Meguiar's All Purpose Cleaner Plus D103
Maybe the best degreaser on the market with fast cutting power, great value and ease of use. Dilute 10:1 and use it to the wheel wells, engine bay, tires, stubborn build ups and some of the interior of the vehicle!
128 oz
Meguiar's Super Degreaser D108
Extra strong degreaser that can help you quickly clean an engine bay, wheel wells, under carriage, etc. Dilute 10:1 for the best value and safe usage.
128oz
Meguiar's All Purpose Cleaner D101
A great all purpose cleaner for vinyl, rubber, fabrics, leather and more. It's the perfect product for professional detailers who need a good value (dilute 10:1) and one product that can do it all to save time.
128 oz
Meguiar's Wheel Brightener D140
Extra strong wheel cleaner that is perfect for a professional detailer who want a quick cleaning. Dilute it down 4:1 before trying a stronger concentration. Try it today and you may never go back to another cleaner.
128 oz
Meguiar's Hyper Dressing D170
One of the best tire dressing on the market that you can use at 1:1 for an overly glossy appearance or dilute 4:1 for a more natural look. Must have for professional detailers!
128 oz
Meguiar's NXT Tech Wax 2.0
A great all in one product that has cutting particles to remove surface imperfections while leaving a coating of protection. It will enhance the shine greatly with just one application.
18 oz
Meguiar's Scratch X 2.0
This NEW revised formula helps you remove scratches by hand with ease. Just a small drop on a soft cloth worked in a circular motion can remove swirls and very fine scratches.
7 oz
Meguiar's PlastX Clear Plastic Cleaner and Polish
Clean, shine and protect your plastic surfaces with the Plast-X. Use it on headlights, tail lights, convertible top windows, motor cycle windshields, etc.
10 oz
Meguiar's Professional DA Polisher Backing Plate W67DA
5" Backing Plate that has more flexibility and is easier to work with. Works with 5.5" and 6.5" pads on DA buffers like the Porter Cable 7424 XP.
Meguiar's Solo Easy-Buff Rotary Backing Plate W66
Makes using a rotary buffer safer and easier with increased maneuverability and control. Use with 6.5" pads or larger on a rotary buffer.
Meguiar's 1000 Grade - Unigrit Sanding Block
A highly effective way to help remove deep scratches and chips in the paint. More effective than traditional sand paper with it's Unigrit design which leaves behind a smoother surface that is easier to polish. Coming Soon (10/17): 1500 Grade Unigrit Sanding Block & 2000 Grade Unigrit Sanding Block
32 oz & 128 oz
32 oz & 128 oz
32 oz
32 oz
16 oz
22 oz
128 oz
128oz
128 oz
128 oz
128 oz
18 oz
7 oz
10 oz
Meguiar's 1000 Grade - Unigrit Finishing Sand Paper
Meguiar's 1200 Grade - Unigrit Finishing Sand Paper
Meguiar's 1500 Grade - Unigrit Finishing Sand Paper
Meguiar's 2000 Grade - Unigrit Finishing Sand Paper
Meguiar's 2500 Grade - Unigrit Finishing Sand Paper
Meguiar's 3000 Grade - Unigrit Finishing Sand Paper
9" x 5.5" sheet
The Unigrit sand paper is a highly effective way to buff out deeper imperfections. Always follow up more aggressive sand paper with a lighter girt sand paper and polish.
We have several more new Meguiar's products on the way that should be here by next weekend (approximately 10/17) including the M34 16oz and 128oz Final Inspection, M40 16oz Rubber/Vinyl Cleaner and Conditioner, 1500 Grade Unigrit Sanding Block, 2000 Grade Unigrit Sanding Block, 5 1/2" Sanding Backing Pad. If there are any products from Meguiar's that you really like and we don't have listed please let us know!
Thank you for taking some time to look over the Meguiar's products we selected. We hope you can take some time to read more about them and try some for yourself. If you need any recommendations, advice, etc. please don't hesitate to contact us. We look forward to hearing from you!
9" x 5.5" sheet
We just got in a few more Meguiar's products that are in stock and ready to ship!
Meguiar's Vinyl and Rubber Cleaner and Conditioner M40
Clean and Condition your rubber and vinyl pieces both inside and outside your vehicle. Versatile and highly effective.
16 oz Price $11.99
Meguiar's Final Inspection M34
Clean and shine your paint with this superb quick detailer.
16oz Price $7.99
128oz Price $26.99
Meguiar's Unigrit Sanding Block
Makes sanding your paint simply and easy.
1500 grade Price $18.99
2000 grade Price $18.99
Meguiar's 5 1/2" Sanding Backing Pad
Wrap your sand paper around this semi-flexible backing pad for even pressure and ease of use.
Price $3.74
If you see any of your favorite Meguiar's products missing please let us know.
16 oz Price $11.99
16oz Price $7.99
128oz Price $26.99
Price $3.74
Jul 29, 2019 11:13 AM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
