How to relocate garage door opener (lift!) - 6SpeedOnline - Porsche Forum and Luxury Car Resource
Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > Tech Stuff > Garage Forum
Reload this Page >
Notices
Garage Forum Share pictures of your garage with the rest of the 6speedonline members. Learn about Garage flooring, painting, art, and more in this forum.
Old 05-07-2012, 06:22 PM
NikosF will become famous soon enough
I want to get a Bendpak HD9 and have realized that my garage door opener is in the middle of where I want my upper car to be when in storage mode.
Looking at this thread it looks like his motor is closer to the door than mine: https://www.6speedonline.com/forums/...lled-pics.html
Here's what mine looks like. Can I get it moved? It appears that the track needs to be long enough to do a full pull of the door up - so is it even a possibility?
Lift will go where the black car is:
Old 05-08-2012, 11:12 AM
xamfed's Avatar
xamfed is on a distinguished road
Look at the LiftMaster 3800 Residential Jackshaft Garage Door Opener
Amazon Amazon
Old 05-09-2012, 03:58 PM
Thanks! THat looks like the answer (except I need new tracks now ). Between this garage door, the lift, installation, 220V electric and epoxying my floor, this is turning into a big project!
Old 05-09-2012, 04:25 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
you should raise the track to the ceiling anyway because you won't be able to open it when a car is on the lift high in the air.
Look at the link you posted and now imagine the door opens with the car on the lift...
The other option is to get the door track at an angle so that the door goes at a certain degree instead of staying flat to the ground.
Old 05-17-2012, 12:43 PM
ATK_Designs is on a distinguished road
Let us know how to goes. I'm in the same boat and the solution would be extend the track and re mount the motor
Old 05-17-2012, 04:34 PM
I'll post a picture when it's done.
I need to replace my tracks so they run along the ceiling as well as buy a new opener (jackshaft). It's a $1000 - 1500 expense installed.
Old 05-17-2012, 06:36 PM
Johnsoto11226's Avatar
Johnsoto11226 is a name known to allJohnsoto11226 is a name known to allJohnsoto11226 is a name known to allJohnsoto11226 is a name known to allJohnsoto11226 is a name known to allJohnsoto11226 is a name known to all
Job Well Done!
Old 06-10-2012, 07:15 PM
RRaider911's Avatar
RRaider911 is on a distinguished road
I completed the same project last year and could not be any happier with the turn out. Hired a garage door guy to reconfigure the rails so that they were closer to the ceiling and had him install a new liftmaster opener that raises the door from the side of the spring. In the pictures you can see the difference between the new raised side and the other door that was not updated.
Old 06-28-2012, 01:47 AM
pluto is on a distinguished road
garage door installation
A well experienced garage door installer came and did the job for me. Now i do not have to worry about anything at all.
Old 11-01-2013, 07:47 PM
wolfnards has a spectacular aura aboutwolfnards has a spectacular aura about
how much did that cost? I called a well reputed garage door company and they said it is their policy not to retrofit current doors to be high lift, so they only do new installations... my garage is only 8 years old, and doors are just fine. should i find another place to retrofit, or do i have to spend the $$$ to get new doors?
Old 11-02-2013, 09:36 AM
RRaider911's Avatar
I think I paid about $900 to have the rails in my garage raised and a new opener installed (See top left corner in 2nd pic above). The installer didn't have to do anything to my existing doors. Took about 3 hours to complete the job. The rails used to be the same height as the ones on the other garage door in pic 3.
Old 10-31-2017, 03:29 AM
Regsns14 is an unknown quantity at this point
You have paid genuine , all garage door repair experts charge this much amount for such work. But from now if you call expert for any repair first confirm the rates from market and then hire then for repair.
Old 10-31-2017, 03:30 AM
Old 12-03-2017, 07:59 PM
David Ferguson is an unknown quantity at this point
Liftmaster 8500
Attachment 509054
Attachment 509055
I use a jack shaft by liftmaster. I believe they are 8500? They connect to the shaft above the door. They are WiFi compatible meaning you can open and close them from your phone as well as see if and how long they have been closed. You can even have it send you an alert when the door is open for when Forest Buler is house sitting.😎
Old 02-06-2019, 06:44 AM
richardchristophe is an unknown quantity at this point
This is pretty interesting that jacl shaft help to give an alert for opening and closing of garage door. Thanks for sharing guys.
03-21-2019 11:04 PM
J9277655
12-28-2015 11:01 PM
RallyBird
10-07-2015 01:20 PM
gulf gt
08-27-2015 10:27 AM
I'mAllIn
08-25-2015 09:44 AM
Quick Reply: How to relocate garage door opener (lift!)
Join 6SpeedOnline
Visit our Sponsors
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
