Glistening Perfection Spotless Water de-ionized filtration system Group Buy
OK guys….you’ve asked for it and CR Spotless finally gave me the thumbs up. As a 6speedonline members-only offer:
DIC-20 Retail: $449.99 + $44.90 in accessories....$494.89
5-10 units: $427.50 S+H included
10+ units: $416.25 S+H included
Product Description:
Hard water spots can destroy your vehicle’s finish. That’s why CR Spotless Water Systems created a de-ionizing system that takes out all of the minerals in your water so you can just WASH, RINSE, and WALK AWAY! That’s right! With a DIC-20 Spotless Water System™, you can let your car, RV, house windows, etc., air dry with no worries that hard water spots will appear. Say goodbye to towel drying and the scratches that towels and chamois can cause. You can even give your car a quick 5 minute rinse between washes to keep it looking great all the time.
Besides cars, de-ionized water is perfect for washing and SPOT-FREE rinsing of your:
Input TDS Level Expected Yield (# of Gallons)
50 ppm............. 1600 gallons
100 ppm............. 800 gallons
200 ppm............. 400 gallons
400 ppm............. 200 gallons
Please PM or call 949-355-4911 to order. Orders will ship once minimum of 10 units have been placed.
- Cars/trucks
- RVs
- Motorcycles
- Boats
- Golf Cars
- House Windows
- Patio Furniture
- Decks
- DIC-20 with in-line TDS Meter
- (2) 20” Cartridges Filled with De-Ionizing Resin
- 4’ Inlet Hose (Attaches to Hose Bib)
- Nozzle (7 Pattern Garden Sprayer)
- Roll of Teflon Plumber’s Tape
- Housing Wrench
- Quick Start Guide/Warranty Card
- Bonus: einszett Perls Shampoo ($9.95 value)
- Bonus: Glistening Perfection 11-Step Detail Guide ($10.00 value)
- Bonus: (2) 100% Australian Sheepskin Wash Mitts ($24.95 value)
- A water de-ionization system, not a water softener
- Removes ALL minerals and dissolved solids from the water
- Battery operated, in-line TDS meter to monitor the water quality in and out of the system
- Ergonomically designed cart with a padded handle
- Easy to refill resin or replace cartridges when needed
- Seven pattern garden hose nozzle with FLAT setting
- 4’ inlet hose to attach to hose spigot
- Produces 100% pure, mineral-free de-ionized water
- Pure water evaporates without leaving any spots behind
- Know when it’s time to change or refill the cartridges before spots appear
- Take it anywhere… easily rolls and maneuvers with one hand
- No need to send it back for regeneration
- Flat spray pattern restricts water flow and increases pressure
- Everything is supplied even the car shampoo and mitts!
- Standard Garden Hose Bib
- Need to Restrict Water Flow to 4 Gallons Per Minute or Less with Supplied Nozzle on FLAT Pattern or Optional Pressure Washer
I got a PM about the refill of the resin. If you buy the resin in the bulk container, it's not too big, it's $195. The bulk resin will recharge the unit 3 times, so that's $65 a refill. You will typically get anywhere from 10-30 rinses out of the system. If you wash weekly, that's about 2.5-8 months of resin.
Almost forgot.....ends October 31st. I've got 5 PMs in addition to Oak, but Oak is the only one confirmed right now. So, we're almost at ten....you're not going to find a better deal on the web; I'll match if you do.
Up to 5 confirmed, so we've met the minimum....
I have been looking at these. I live in Tampa Fl and we have hard water. I'd like to find out how many complete washes I would get from the system. I wash my car 1 to 2 times a week.
Thanks! Mike
Thanks! Mike
How many washes you get depends on how hard your water is and how much you use. Let's say your water is hard and is around 400 ppm; you should get about 200 gallons of di water. Now if you use the system all the way through and use about 10 gallons, on the high side, you will get 20 washes. If you use normal water and rinse with the di, about 5 gallons, you can double the number of washes to 40. Then it becomes more cost effective. So even if you wash your car twice a week, that's 20 weeks, 5 months of life out of one charge/recharge.
sorry for the stupid question but does it really work? like you can just spray it and walk away? i tried the stupid mr. clean car stuff and walked away and came back to water spots if it really does work then for sure count me in!
The CR Spotless comes with a 30-day Money Back Garauntee that both CR and Glistening Perfection will stand behind. If something should ever go wrong with the unit, you can always contact Glistening Perfection, even after the 1-Year Warranty, to make things right. We stand behind EVERYTHING we sell.
