Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > The Marketplace > Group Buys
Reload this Page >
Torque Solution Dog Bones, Trans & Engine Mounts GROUP BUY!!!
Notices
Group Buys This forum is for special group purchases offered by our 6speedonline sponsors. Join in on a group buy purchase, and save big!
Old 03-13-2013, 12:03 PM
AWD Motorsports's Avatar
AWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond reputeAWD Motorsports has a reputation beyond repute
Ok guys as requested we are setting up a group buy on some Torque Solution Products.. Dog bones was the main request but we will offer some other items such as Engine & Transmission Mounts.. If you need any other items from Torque Solution just PM me.. I will add the engine mounts and trans shortly..
Torque Solution Rear Dogbone Kit is designed to correct the rear suspension geometry on your lowered Porsche 996/997. If you are experiencing uneven tire wear due to too much camber this kit will help bring your alignment back in spec for better performance and longer lasting tires. The factory camber adjustment range is not enough to bring your car back within spec after lowering the vehicle. if you plan to track your car or get the full life of your tires these are a must have..
Made of 6061-T6 Aluminum w/ FK Rod Ends. 4 links Total Included in Each Package Requires NO modification to chassis, direct bolt on replacement part. Can be used on daily driven street cars & is highly recommended for Street or Track setups..
Fitment: 996TT/GT2/GT3/C2/C4/C4S 997TT/GT2/GT3/GT3 RS/C2 /C4s
•Made out of lightweight 6061-T6 billet aluminum
•Street and track torture tested
•Black anodized / Torque Solution Laser engraved
•FK Bearing Rod Ends
•Lifetime Warranty
•Made in USA
459.00 SHIPPED GROUP BUY for all 4 pieces[/SIZE]
https://www.awdmotorsports.com/Produ...TS%2DPOR%2D002
Torque Solution Porsche Engine Mounts are designed to limit the amount of Engine movement from side to side which throws off the balance of the car under load. The factory mounts allow the engine to move which gives the feeling of a sloppy drivetrain. The mounts will give the car a more direct feel and more precise driver input to the vehicle. You can expect a much better feel under Braking, Acceleration, & lateral G's. While typically most " Race Cars " use a SOLID MOUNT, this solution is less harsh and still maintains better control of the engine movement without the issue of Solid Mount Vibration. The next issue with Solid mounts is the transmission of noise from the chassis to the knock sensor on the engine which can result in a tuning nightmare. These mounts will not affect knock sensor like solid mounts do. We are using a 75 Durometer Bushing with a complete billet mount housing.
299.00 Shipped!!!
Fits all Years 996/997 Turbo & NA..
** Note ** The Urethane color shown in Blue is to show the actual Urethane placement.. Actual Urethane color will be Black..[/SIZE]
Transmission Inserts 129.00 SHIPPED
http://www.torquesolution.com/Search...ission&x=0&y=0
Toe Links 349.00 Shipped ( ETA late april )
Torque Solution Porsche 996/997 Cayman & Boxter Rear Toe Links will help restore the proper suspension geometry for lowered vehicles.. The factory control arm do not have the adjustment range needed to compensate when lowering your 996/997, Cayman or Boxster.. This results in poor tire wear and an insufficient contact patch.. This kit will provide the additional adjustment needed. These work great for street and track use and do not transmit harsh vibration thru the vehicle..
2 links Total Included in Each Package
Lifetime Warranty
Here they are in Action on 1 of the fastest Street GT3 RS to run Sebring around here..
Usernames for Dogbones
1.Porka - Payment Sent
2.ADAMSONS - Payment Sent
3.Johnnyb2016 - Payment Sent
4.nevert00fast - Payment Sent
5.Sharp - Payment Sent
6. West Coast - Payment Sent
7.
8.
9.
10.
Usernames for Engine Mounts
1.
2.
3.
4.
5.
Usernames for Trans Mounts
1.ADAMSONS - Payment Sent
2.Onefastman1 - Street Version Inserts
3.Sharp - Payment Sent
4.
5.
Usernames for Rear Toe Links
2.nevert00fast - Payment Sent
3.Reborn996 - Payment Sent
4.Neb - Payment Sent
Tel. 954.919.9660
AIM=Mikeatawd
www.AwdMotorsports.com
http://farm6.static.flickr.com/5244/5379038354_e179f368cd_z.jpg
  • 2008 Porsche 997 GT2
  • 2017 Hellcat Charger
Old 03-14-2013, 03:10 PM
onefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to all
What about engine mounts?
Old 03-14-2013, 03:15 PM
Engine mounts added.. Will add trans mounts shortly
Tel. 954.919.9660
AIM=Mikeatawd
Old 03-14-2013, 03:24 PM
Any chance for a rear toe link GB?
Old 03-15-2013, 11:38 AM
nevert00fast will become famous soon enoughnevert00fast will become famous soon enough
Can you explain what I need to get rid of excess negative camber from lowering springs? What does the rear toe link kit do that the dogbones don't? TIA
Old 03-17-2013, 05:36 AM
Mikelly's Avatar
Mikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond reputeMikelly has a reputation beyond repute
The rear Dog Bones will help you "stand" the tires upright by lengthening the dogbones, which removes negative camber. That's why they are adjustable. Rear toe links adjust your toe in the rear wheels. Pointing them in towards or out away from each other front to rear.
Mike at AWD is a solid dude who builds good chit. You guys should take advantage of this!
Mike
Old 03-17-2013, 01:39 PM
porka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant futureporka has a brilliant future
Mike
Listen to the man - vendors are asking close to $1k for these parts.. AWD is asking less then that shipped!
Want these on my car asap
Old 03-17-2013, 02:40 PM
Mike
Thanks. So if my goal is just to remove excess negative camber then I'd just need the dogbones? Are toe settings limited on lowered cars with stock Rear toe links?
Old 03-17-2013, 06:55 PM
Per AWD -
My conclusion - Your oem setup has the toe link for alignment adjustments.. the benefit of the heim joints are that they remove the rubber bushings therefore offer more accuracy and removes that rear wiggle under hard brakings.. im talking about in excess of 100mph.. you are essentially eliminating all the cushy rubber and going solid!
there worth the money!
Old 03-19-2013, 11:20 AM
ADAMNSONS's Avatar
ADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to behold
What about the Trans mounts??
Old 03-19-2013, 11:31 AM
Originally Posted by porka View Post
Per AWD -
Now we just need to get them to include them in the groupbuy.
Old 03-19-2013, 01:26 PM
ADAMNSONS's Avatar
I am in for a set of the dog bones if you can get the trans mounts too.
It says they will fit the 996 GT2s… Can you please confirm? I want to make sure.
Old 03-19-2013, 09:12 PM
ADAMNSONS's Avatar
Sign me up.
Old 03-20-2013, 10:45 AM
Any word on trans mounts?
I am interested in a package deal on all 3.
Also, I would really like to see a deal on the rear toe arms too.
Old 03-20-2013, 11:51 AM
It says they will fit the 996 GT2s Can you please confirm? I want to make sure.
Mike with AWD confirmed they fit 997 and 996 Inlcuding GT2!
Quick Reply: Torque Solution Dog Bones, Trans & Engine Mounts GROUP BUY!!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
