Brembo 2pc PCCB Replacement Rotors Released 380x34mm
Price is $2095/pair. Vivid Racing has them INSTOCK for same day shipping. You can also order online here - http://www.vividracing.com/catalog/a...rotors&x=0&y=0
Porsche has engineered the ultimate in braking with their ceramic PCCB brake system on the 997 GT3, GT3RS, and GT2. However, for those guys that are using their vehicle to its limit, these rotors can wear out fast. If you have not checked cost on replacement rotors, don't, they are expensive! Brembo has brought in a solution for PCCB owners who want to not only replace their rotors, that get a much improved rotor with their new 380x34mm 2pc rotor. The wide annulus disk is designed to give incredible braking performance with its large surface area. The engineering of these rotors comes from Brembo's top level racing divisions. The same engineering goes into their brake kits as used in many professional racing vehicles. The slotted venting pattern that the rotor has helps dissipate heat faster and will not crack like drilled rotors. One reason you see most race cars with slotted rotors is because of this. Drilled rotors look nice, but true braking performance is done with slotted discs.
The hats and rotors utilize the Patented McLaren floating hardware as pictured. The exclusive purpose of Brembo’s McLaren hardware is to mimic the function of a full floating disc while minimizing the noise that can become a nuisance on the street. While the McLaren hardware does an excellent job of completely reducing this noise, it would have been pointless to waste all of this engineering, testing, and effort on just one function when the full floating rotor serves many other important functions on its own. For the McLaren design, "anti-rattle" is only one of the functions. The hardware must be able to minimize the noise while still allowing the disc to properly float and achieve every additional benefit of a floating disc. The Brembo rotors are 100% Brembo made. These come directly from the Brembo factories with the utmost attention to detail, quality control, and R&D. No outsourcing or collaboration parts are done, so you can continually trust the Brembo brand.
The addition of these rotors offers an incredible reduction of unsprung and rotational weight. The fully floating hardware allows the disks to seek a true center line for improved pedal feel and modulation in racing or hard driving conditions. With the quality of these Brembo rotors, it is virtually impossible to warp the rotors and gives even pad wear and rotor wear. Overall, these disks will last longer then the OEM units while giving premier braking performance.
Comparatively to the competition, the Brembo product uses superior materials, manufacturing processes, and the R&D with quality control that you can only expect from the Brembo name. Having first hand used other products on the track and street, Brembo has continually proven itself to be the best quality and have the proper performance level that high end Porsche drivers demand.
These rotors are specific for the Porsche 997 GT3, GT3RS, and GT2. Because these rotors are PCCB replacements, you must also change the pad. Brembo and Vivid Racing recommend going with the Pagid Yellow pads to work with these rotors. Choose the option below.
View Installation Instructions Here
04-28-2022 12:38 AM
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
turbosonoma
08-19-2015 02:05 PM
