coolant leak
Old May 12, 2004 | 03:20 AM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
coolant leak
For those that do not make it to the other boards... Just wanted to post about a problem I had with my cooling system. I had a low coolant resevoir that I topped up several times. After running I would always find the resevoir low. My dealer thought it was a cracked coolant resevoir and scheduled me an appointment. Well today they were able to locate the source of the leak... they need to replace the "coolant control valve" going to the engine. Apparantly this valve controls the rate of coolant flow to the engine, sort of like a thermostat. The part is ordered and I should get the GT back before the big weekend at Sebring.
Old May 12, 2004 | 04:18 AM
watt's Avatar
watt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to beholdwatt is a splendid one to behold
if that valve just restricts flow, where is all the coolant you're adding going to? or does the valve leak?
Old May 12, 2004 | 04:26 AM
Sloth's Avatar
No, the valve is the source of the leak.
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
