TECHART 60mm LIFT KIT for 997 Coilover Suspensions
TECHART Noselift system will be ready to ship by the end of this month.
This system uses a button in the cabin to lift the front end for driveways, ramps, speedbumps, etc.
It attaches to factory coilovers (GT3 or GT2), TECHART coilovers or Bilstein PSS9/10 coilovers. It will not work with stock non-coilover suspension
Here are some the of the features
1) Works with Porsche PASM active suspension
2) Works with an integrated OE-look console switch
3) Works up to 40 mph
4) Has the highest amount of lift at 60mm (almost 2.5 inches)
5) Hydraulic system is quiet and fast 6 sec to full lift.
6) Available in a package with TechArt Coilovers
7) 4 year/50,000 mile warranty
PM me with any questions, pricing or availability.
So the main difference between the Cargraphic lift system and the Techart lift system is the fact that the Techart system is mechanical? They both lift at about the same rate and same height?
Thanks!
Matt
Thanks!
Matt
Both are hydraulic.
Where can you see that?
"Hydraulic system is quiet" it states.
The Cargraphic lift system is run off of the tire compressor for the flat tire system we have.
Need clarification please.
Whereas the TechArt system is clearly hydraulic:
From the looks of the kit, fluid is pumped into the shocks, extending their travel. I see lots of points of failure for this system and I would rather spend far less and use an easily replaceable airbag that's separate from the shock. If the hydraulic system leaks, you're screwed. If the air system leaks, your car functions normally without the benefit of lifting the front end.
The safe bet is to not add even a remote possibility of shock losing its lifeblood.
True, plus you have to install the hydraulic pumps somewhere. Whereas, the Cargraphic system uses the cars compressor located in the trunk.
Install of the cargraphic system looks much simpler.
Here are some of the advantages of the TechArt System.
1) Works with Porsche PASM active suspension (K&W system does not)
2) Works with an integrated OE-look console switch vs. a key fob remote
3) Works up to 40 mph vs. 35 mph
4) Has the highest amount of lift at 60mm vs. competitor's 45mm to 55mm
5) Hydraulic system is quiet and fast (6 sec vs. 43 sec) vs. compressed air system that is noisy, hot and slow
6) 4 year/50,000 mile warranty vs. no warranty disclosed yet
