Hoosier R6 Tire Questions
Old Jun 29, 2010 | 04:20 PM
vpmick's Avatar
vpmick is infamous around these partsvpmick is infamous around these parts
I have always had my Hoosier R6 tires balanced when mounted on my track wheels. This weekend at the local PCA DE I had a guy tell me it was not necessary and was actually a waste of money to have your track tires balanced due to the amount of rubber that sticks to the inside of the wheel. Anyone have any thoughts or input on this? Also we had a lively discussion about tire pressure. I'm at 31 front cold and 33 rear cold...heating up to mid to high 40's. The debate was that going to a higher pressure would extend life with no significant grip loss.
Old Jun 29, 2010 | 05:48 PM
NorthVan's Avatar
I run R6's and start the pressure at 27F+R cold. I am for about 36 hot.
As for balancing, I get it done for free so it doesn't bother me to have it done, however quite often my balancing weights will fall of from the heat (even with aluminum vent tape over top), and I don't notice much (if any) vibration, as my speed isn't constant.
Old Jun 29, 2010 | 08:09 PM
schillster1@aol's Avatar
schillster1@aol is infamous around these parts
I just started running R6's. I was told by a experienced driver that balancing is necessary but the Porsche balancing is not. Run the tires "hot" at 31/32 on front and 35/36 rear.
Old Jun 29, 2010 | 08:20 PM
jenk12m's Avatar
jenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant future
i usually get mine balanced but for my last event i didnt and there was no difference in feel on the track. i start cold at 28 all the way around
Old Jun 30, 2010 | 07:54 AM
kukri's Avatar
kukri is infamous around these parts
What does that mean?
Old Jun 30, 2010 | 10:54 PM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
you can read the hoosier site all day long, on a rear drive 996 997 variant, if you go outside of 32-36, you are not optimizing grip. use a pyrometer probe and see for sure.
Old Jul 1, 2010 | 01:58 AM
drnano's Avatar
drnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to behold
Tire manufacturers often recommend a pressure slightly higher than the level which optimizes grip, to maintain stiffer sidewalls and reduce the likelihood of tire failure.
Old Jul 1, 2010 | 08:32 AM
NorthVan's Avatar
I look at Tire Pressure and Tire Roll Over, as stated I aim for 36lbs, and also watch how much of the tire I am using.
Old Jul 1, 2010 | 11:35 AM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
Thumbs up
Originally Posted by mikesmith
Read the Hoosier Site, 38-43 Hot!!!!!!!!!
What he said.... ^^^^^ By HOT they mean take the pressures the instant you get off the track.. If you wait for 45 seconds, you will see a lower pressure reading by a couple of pounds.
Old Jul 1, 2010 | 01:47 PM
kush's Avatar
kush is infamous around these parts
+1. I adjust to 36 all around aiming for 38-40 on the track. By time I'm adjusting in the paddock they've cooled a few degrees.
Old Jul 2, 2010 | 04:37 AM
When you take the car to an authorized Porsche dealership they balance your tires using "Road force balancing". It costs anywhere from $100-200+. I've been told for track purposes to just get them balanced at a normal tire store.
Old Jul 2, 2010 | 08:13 AM
atr911's Avatar
atr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud ofatr911 has much to be proud of
Road Force, haha.
That system is only good for identifying problems with rims and, or tires. It doesn't give a better balance unless there is a problem and the wheel/tire needs to be indexed. Indexing DOES reduce the amount of weight required but if they're charging you $100-200 to balance, ask them to lube it up first please.
On the topic of the hoosiers, they've done alot of research with Porsche specifically. Call hoosier directly and talk to them. They recommended I run 34-36 hot in front and 36-38 in back. They emphasized that this was a STARTING point. Also worth mentioning that I'm using the 19" tires.
Mooty makes a very good point that track surfaces and driving styles vary and a pyrometer is really the only way to be sure. Pyrometer should be used on NEW tires to evaluate setup. The older the tires become the less viable the pyrometer results because the tires have 'worn' into the setup.
*disclaimer* This is just based on my research.
Old Jul 2, 2010 | 12:59 PM
Yeah, I should clarify that. $100-200 to mount and "road force" balance!
Old Jul 2, 2010 | 01:07 PM
atr911's Avatar
If you bought the tires from them, depending on what you paid, you should expect to pay 25-30 per tire, tops.
COBB Tuning
Nov 9, 2015 08:02 PM
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
Sep 3, 2015 09:34 AM
orbelo
Aug 30, 2015 12:26 PM
