Ramps for trailers.. trailex.. and gt3s
i have a trailex 7541 model...
what do i need to load up the RS properly... ramps, blocks? |
Get your self a set of the long low profile race raps, easy, and safe and will load with no issues. If your car is low, in addition to that, you can jack the front of the trailer up a little to tilt it back to help.
As long as you asked, Race Ramps would be a great addition. BTW, congrads on the new P-car. Available via Sponsor: Reverse Loqic Limited. No affiliation, just very satified with mine.
+1 for Fred at reverse logic
Just trailered mine home after purchasing, and found removing the front lip gave just enough clearance.
when i bought my 996 it was so low i couldnt get on my laramore trailer. i jacked the front as high as it would go and used 2 2x10x8 pieces of lumber. cut 2' off at a 45* and put it on top the 6' ft piece under the ramps. this gives you a nice angle to keep the front from hitting. cost was under 20$
you do have ramps that came with the trailer correct? btw get ready for all sorts of folks driving next to you looking at the car!! they drift towards you trying to get pics!! :) |
