Graham Rahal Performance Silver Porsche 991 GT3 RS Center Section Exhaust & Roll Bar
Attachment 1
Center Section Exhaust & Roll Bar Safety Package Install
In collaboration with Graham Rahal Performance, we would like to present this Silver Porsche 991 GT3 RS. To provide proper restraint and deliver a more aggressive exhaust note, GRP installed our Roll Bar Safety Package & Center Section Exhaust at their new state of the art facility in Indiana. BBi Autosport is proud to have partnered up with IndyCar Series driver Graham Rahal to launch his very own aftermarket tuning brand Graham Rahal Performance. We will be working closely with GRP as one of our premiere dealers and a technical partners.
Upgrades
Engine
• GRP/BBi 991 GT3/RS Center Section Exhaust
Safety
• BBi Autosport StreetCup Roll Bar
• BBi Autosport Sub Belt Bar
• Schroth Racing Profi II GT3 HANS Harnesses
Sound Clip
www.instagram.com/p/Bchs9msjsMR
BBi/GRP Autosport Porsche 991 GT3 / GT3RS StreetCup Center Section Exhaust
Made in the USA, this BBi/GRP Co-Branded Center Section Exhaust is TIG welded out of brushed T304 stainless steel and features the main pipes merging in the middle to function as an x-pipe. By retaining stock side mufflers and valves, the factory "sports button" feature is kept to conveniently switch back and forth between the aggressive "sport" mode during spirited driving sessions and the quieter, more civil "non-sport" mode for minimal noise on the highway.
Features
BBi Autosport Porsche 991 GT3 StreetCup II Bolt-In Roll Bar
Features
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
If you have the optional Sport Bucket seats and planning to install 6-point race harnesses, then you will need this bracket. This bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
About Graham Rahal Performance
499 Southpoint Cr. Suite 105
Brownsburg, IN 46112
Website: www.grahamrahalperformance.com
Facebook: www.facebook.com/GrahamRahalPerformance
Email: gr@grahamrahalperformance.com
- Jerry@BBiAutosport.com
Upgrades
Engine
Safety
Sound Clip
Features
- Delivers deep aggressive exhaust sound
- Significant weight reduction
- Retains Sports Exhaust Button function
- TIG welded T304 brushed stainless steel construction
- Factory primary side mufflers & catalytic converters are all retained
- Direct bolt on replacement
- Fits all 997 & 991 GT3/GT3RS models
- 50 State 100% emissions legal
- Will not void warranty
- Optional black ceramic coat finish available
- Made in the USA
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
- Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
- Designed to work with stock seats or any aftermarket seats on the market
- Allows full seat travel to accommodate taller drivers
- Can be used with stock seat belts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
BBiAutosport
12-08-2017 09:08 PM
BBiAutosport
12-08-2017 03:17 PM
