Track set up
Track set up
I am looking for some allingment input for my GT3 for the track and autocrossing. I know that these are 2 different set-ups...I am looking for a compramise. In stock form it feels like the front needs to be toe'd out and some negative camber needs to be dialed in as well. I have not taken tire temps yet. My first track event is not until next month. Thanks, Karl
Side question: How does one post a photo. Every time I try I get a file too large error message. I am down to 72DPI and minimal dimensions. I see far larger files posted all over this site! Thanks.
Karl, I haven't been successful in posting pix, so you are not alone.
Here is a very aggressive track set up, you can take this to you shop, and ask for a compromise between this and the street spec set up.
Front axle:
Camber: -2.5º
Max camber difference, left/right: 5'
Toe total: +5'
Toe difference at 20° lock: -1°20' +/- 30'
Caster: 8° +/- 30'
Max caster difference, left/right: 30'
Front height: 115mm
Swaybar – 1 from hard
Rear axle:
Toe total: 35’ +/- 2'
Max toe difference, left/right: 5'
Camber: -2.3° +/- 5'
Max camber difference, left/right: 10'
Rear height: 128mm
Front axle:
Camber: -2.5º
Toe total: +5'
Caster: 8° +/- 30'
Front height: 115mm
Rear axle:
Rear height: 128mm
Re: Track set up
you can post it. In order to tell the size of your photo you want to post...open up the photo in a browser and right click select properties on it. It will tell you its size. It also can not be bigger than 800 x 600 pixels in resolution I believe...
Jul 29, 2019 11:13 AM
