2 997 GT3RS corner balance and full setup done! Pics!
Father and son team. Orange car is the old man's and the green car is his son's, both weight in at about 195lbs. Orange car has full cage, racing seat, interior carpet removed, racing steering wheel and standard brakes. Green car is completely stock with PCCB brakes. Alignment specs are a little bit more aggressive than "competition specs" listed in the owners manual. Orange car is pretty much for track use while the green car sees both street and track use. Alignment sheet and corner balance specs shown is for the green car. Orange car alignment specs are identical, balance specs are about the same, the only difference is that the orange car is slightly lighter. Both cars where measured with 3/4 tank of gas.
Green car left cross %.
Green car right cross %.
Green car after adjustment settings. All angles are in degrees and minutes.
Corner balance sheet.
Listed below is before full adjust.
Empty weight total is 3292.
LF: 651 RF: 626
LR: 1006 RR: 1009
Empty height total in mm.
LF: 115 RF: 115
LR: 132 RR: 132
Add 193 in drivers ballast, perform corner balance and ride height settings, perform alignment to achieve perfect corner balance listed below and shown in above pictures.
Loaded weight total is 3485.
LF: 703 RF: 654
LR: 1090 RR: 1038
Loaded height total in mm.
LF: 110 RF: 110
LR: 122 RR: 125
Loaded cross % total.
Front 39%
Rear 61%
Left cross 50%
Right cross 50%
Note: Total added weight for wheel clamps and alignment heads is 110lbs, actual empty weight is 3,182lbs and loaded actual weight is 3,375lbs.
LF: 651 RF: 626
LR: 1006 RR: 1009
LF: 115 RF: 115
LR: 132 RR: 132
LF: 703 RF: 654
LR: 1090 RR: 1038
LF: 110 RF: 110
LR: 122 RR: 125
Front 39%
Rear 61%
Left cross 50%
Right cross 50%
Corner Balance In Ne
I am in Eastern PA. and was wondering if anyone has used or knows on anyone in Eastern PA. or North Jersey that they would reccomend to do a corner balance on my GT3 RS?
I don't have any interior shots right now, car will be back later this week...I'll take some pictures then.
does she even need to be cute?
Protosport in Butler NJ, about 10minutes from intersection of 80/GSP, or Deman in Nyack/nanuet area.
04-28-2022 12:38 AM
turbotuner20v
09-11-2015 12:02 PM
Wheel Experts
American Muscle
08-19-2015 09:07 AM
