Novitec Torado Lamborghinin Aventador LP700-4 Program from GMP Performance
Lamborghini Aventador LP700-4 Novitec Torado Package: Performance en Vogue.
When Novitec builds a performance package for a car, they leave nothing out. The new program for the Aventador is no exception and has been developed for maximum form and function. The complete aerodynamic package has been designed and wind tunnel tested in light weight carbon fiber. The aerodynamic components provide improved aerodynamics, while giving the vehicle a more aggressive appearance. Motor performance has been achieved through upgraded engine management software and high quality exhaust systems available in the ultra lightweight material Inconel or stainless steel. To maximize driving performance, suspension components and tailor made wheel and tire combinations provide maximum contact with the road. The Novitec program is completed in the driver's seat where a wide range of products are offered in carbon fiber.
From end to end, Novitec gives you a range of products for your Aventador, so you can make it more beautiful, more powerful, and more a unique expression of you.
NOVITEC ENGINE PERFORMANCE
The in-house developed performance gains are the heart of the NOVITEC program. Massive power development and outstanding performance, coupled with a unique sports car modified for daily use, are the crucial factors that will convince you of the performance delivered, built and designed by NOVITEC.
NOVITEC EXHAUST SYSTEMS
NOVITEC exhaust systems are characterized by using the highest quality materials, a perfect fit and powerful sound characteristic. They are available as individual performance optimizing components with our without flap regulation. The custom tailored tailpipes give the rear end of your vehicle a more aggressive and finished appearance.
NOVITEC WHEELS AND TIRES
NOVITEC wheel and tire combinations are the perfect application for maximum contact with the road. The wheel and tire sizes are matched directly to each vehicle so there is never the need for any adjustment to the original vehicle set up and programming. The design of each wheel fits perfectly and uses the factory tire pressure monitors and center caps. NOVITEC wheels are made exclusively for Lamborghini, Ferrari and Maserati only.
NOVITEC SUSPENSION
NOVITEC suspension and chassis technology offers many different possibilities. The engineers have thought of you and your needs in every way. We offer everything from a spring kit to reduce the height of the vehicle, a complete suspension system that is fully adjustable with detailed specifications and parameters. Your driving comfort and performance are at the forefront of our development.
NOVITEC AERODYNAMICS
Shape and design of the individual aerodynamic components are based on extensive wind tunnel testing to achieve the optimal aerodynamic form and function. in the development of these components, there is also a lot of emphasis placed on the aesthetics of the individual parts so that the visual design accents do not drastically change the fundamentals of the vehicle.
AERODYNAMIC TESTING | Wind Tunnel
Finding a design that not only enhances the aesthetics of the vehicle, but optimizes the aerodynamic function as well, are the two main goals of the construction of our body parts. The NOVITEC aerodynamic program accomplishes these goals in the wind tunnel of the Research Institute for Motor.
Vehicles in Stuttgart. In this special facility, the driving behavior of the vehicles can be reproduced at different velocities. The tests are performed by a simulated velocity of 140km/h. Each part of the NOVITEC aerodynamic program has been tested not only piece by piece, but also in conjunction with each part that we produce to maximize aerodynamic performance. The lift caused by an increase in velocity can be reduced by accurately calculated and developed NOVITEC aerodynamic parts. This design and research deliver optimal driving stability and performance at the highest velocities.
NOVITEC INTERIOR
Our interior design department uses only the finest materials. The vast array of colors let you choose any color scheme.
GMP Performance and NOVITEC
GMP Performance has been a proud dealer of the Novitec Rosso and Novitec Tridente lines for a while and are now happy to add Novitec Torado to our offerings as well. We will carry the entire Aventador package. So feel free to PM, call, or stop on by with any and all questions!
Click here for more information on the Aventador LP700-4 package!
NOVITEC SUSPENSION
NOVITEC INTERIOR
Nissan GTR
Aug 19, 2015 02:11 PM
