Gallardo Superleggera Top Speed Video...
I was talking to Patrick, Houston Larmborghini and he was telling me that depressing the gas pedal through shifting is what causes wear and tear on the clutch. He told me that the driver needs to keep the gas pedal engaged pressed down) all the time when shifting. Correct me otherwise. Thanks.
I have had more than one Lambo dealer person mention that the smoothest way to shift is to lift slightly, but I really doubt there's any significant difference in clutch wear.
That all said, the SL I test drove recently in sport mode shifted way faster than that thing. So either it wasn't in sport, or the guy was lifting.
And with that said, as well, flappy paddles suck.
So do I take it that the wear on the clutch is primarily geared toward the driver continuoulsy launching the vehicle from a stop?
You mentioned that keeping the gas pressed or slightly lifted during shifting holds no merit on the wear/tear of the clutch.
Correct?
Correct?
What do you mean by leaving it in gear? If you are going 5-10mph you would still be in 1st, that would constitute being in gear -right?
As in, leaving it in 1 while moving very slowly, so the computer is constantly feathering the clutch, versus popping it in N and coasting.
But if the condition in traffic only permits you to move at 5-10 Mph, you would have no choice but to feather the clutch.
Or are you saying that it is best to shift into 2nd and coast rather than driving the vehicle in 1st where you are continuously hitting that high rpm band where you should shift into 2nd. Is that what is meant by feathering by not engaging 2nd?
Just trying to get to the bottom of this feathering thing. Correct me if I am wrong. Thanks
tstat
Feb 7, 2026 06:12 PM
albert@velosdesignwerks
Lamborghini
Aug 22, 2015 09:03 AM
