Cost of retrofitting front end lift system to '04/'05 Gallardo?
I've been doing some research on Gallardos and was wondering an approximate cost of adding the front end lift system from the later model onto an older one?
probably to expensive. just buy a 05
Factory or KW?
Would expect running the factory system to be pretty expensive with the lines & buttons |
Might be cheaper to repaint the front bumper every now and then.
KW HLS or the Cargraphics system. I believe both run around 10k or so (give or take a grand or so)... It's not worth it to try to retrofit the factory system from the 05+ cars. If you do decide to go that route though, try to retrofit from an 06+ as it's a little better.
Fair enuf. Time to X off the 04 model from my research.
