Lexus ISF Brembo GT Kit, Painted and Installed by G Rides
We are doing a bit of work on this Lexus ISF. One of the projects for this Lexus was a Brembo Gran Turismo Kit which included 6-Piston Monoblock Front Calipers and 15" 2-Piece Cross Drilled Rotors with Stainless lines for the front. The Rear is a Brembo 2-Piece Cross Drilled Rotor which retains the parking brake and re-uses the stock Brembo Caliper. We had Stainless Steel Brakes Lines made for the rear. The new front Brembo Caliper with pads weighed about the same as the stock Brembo Caliper with pads, however, the new Brembo Caliper provides a pad surface area about 20% larger than the stock pad and going from a 14" rotor to a 15" provides a greater lever arm for more braking leverage and allows greater heat dissipation. The Stock Front Rotor's weighed 25 lbs each, the new 2-piece Brembo Front Rotor's weighed 19 lbs each. The Stock Rear Rotor's weighed 21 lbs each, the new Brembo 2-piece Rear Rotor's weighed 14 lbs each. The brake pedal feel and overall braking performance of this new set-up are excellent.
Stock Brakes:
Successful test fit of stock wheel with the new front Brembo GT Kit.
Paint process begins:
Done with paint, ready for install:
Rears:
Fronts, starting with the Brembo Caliper Mounting Bracket:
We also lowered the car slightly with new Eibach Springs and some new wheels are being built to really show off the Brembo's and should set things off a bit more. Here are some pictures of it now, will have more to share later with new wheels and some other additional modifications.
Stock Brakes:
Rears:
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
ECS Tuning - VW
08-20-2015 03:07 PM
Nissan GTR
08-19-2015 02:11 PM
