FS: 1970 Austin Mini LHD Yamaha R1 Swap 35k
This has been a long project for me. I started with a clean 1970 Austin mini 1275 that was purple at one point and someone painted black. So it has a black/plum color that only shows at certain angles in the sun.
Over 3 years gathering parts from the UK and the time change never helped. They seem to work on a different schedule when it comes to business in the UK.The swap is based on a company in the UK called promotive. Typical power is 170bhp. http://pro-motive.co.uk/ This is Kit 36 out of 40 in the world and the only one in the US that I am aware of that has this fit and finish. I built the car with the intention of daily driving it, but once I got it all together I realized it was a bit too wild as a daily. The R1 I purchased is a Yamaha 2003 5PM Fuel Injected motor The swap involved the following: Yamaha R1 5PW 2002-2003 Injected Yamaha R1 wiring Loom Pro-motive R1 Kit #35 Quaife ATB limited slip differential Wiring looms converted Subframe Core Exchange charge Pro-Motive Reverse Gearbox K&N Air Filter and Carbon Fiber Box 2003 R1 Voltage Regulator 2003 R1 Ecu/CDI box Barnett Carbon Fiber Clutch Barnett Clutch Conversion Kit Koso RX-1N GP Speedometer Dynojet Power Commander 405-411EX Scottoiler Automatic Chain Luber Dual Radiator Setup Suspension was gone through completely and replaced with all aluminum adjustable equipment. 3" Exhaust with extra resonator to quiet the engine down further. AP Racing MG OEM disk brakes Misc Items include: WHITE INTERIOR DOME LAMP Nardi 330mm Drift Steering Wheel VTO Performance 13x7 Superlite Wheels Nardi Steering Wheel Mountney Steering wheel hub Hella E Code Headlamps Corbeau GTS II Seats Fresh Carpet,vinyl wrapped dash, Rear Leather Wrapped seat to match the Corbeaus. Leather boots for the shifter and the ebrake. Kenwood Head unit with Aux input and micro usb at head unit. I use my droid 2 to stream pandora. Image Dynamics Speakers 6" in the doors Image Dynamics Freeair 10" Subwoofer Arc Audio KS Series Amplifier CDT Audio Pillar tweeters Sound Dampening Keyless Entry with 2 keyfobs New Lenses for rear tail lights and blinkers New grille Mini Lite Gold 13x7 wheels Continental 195/45-13 Wheels. These are SUPER RARE and impossible to find. The car has easily of documented 160 hours of labor into it and is the fastest FWD car I've ever been in. The butt pucker factor is HIGH once you get above 7000 rpms and it will stretch its legs all the way to 12,500rpm. Shifting is sequential like a motor cycle. Mechanical reverse knob is mounted just below the shifter. You can go through all 6 speeds in reverse if you were crazy enough. I got the center column dropped for the driver so its less like a schoolbus, and had the interior gone through. New carpet, dash vinyl, rear seat, rear deck, new leather boots for the shifter and ebrake. Car will be for sale after I check the clutch and chain for its new owners. 1/40 in the world. Its number #36 Exterior: https://lh3.googleusercontent.com/__...0/IMG_3286.JPG https://lh6.googleusercontent.com/__...0/IMG_3288.JPG https://lh4.googleusercontent.com/__...0/IMG_8769.JPG https://lh5.googleusercontent.com/__...0/IMG_8772.JPG https://lh3.googleusercontent.com/__...0/IMG_8773.JPG https://lh4.googleusercontent.com/__...0/IMG_8774.JPG https://lh6.googleusercontent.com/__...0/IMG_8776.JPG https://lh3.googleusercontent.com/__...0/IMG_8778.JPG https://lh4.googleusercontent.com/__...0/IMG_8781.JPG https://lh5.googleusercontent.com/__...0/IMG_8784.JPG https://lh6.googleusercontent.com/__...0/IMG_8785.JPG https://lh3.googleusercontent.com/__...0/IMG_8787.JPG https://lh3.googleusercontent.com/__...0/IMG_6062.JPG Interior: https://lh6.googleusercontent.com/__...0/IMG_5833.JPG https://lh3.googleusercontent.com/__...0/IMG_3270.JPG https://lh3.googleusercontent.com/__...0/IMG_3271.JPG https://lh4.googleusercontent.com/__...0/IMG_3273.JPG Matched french stiching https://lh3.googleusercontent.com/__...0/IMG_3274.JPG https://lh6.googleusercontent.com/__...0/IMG_3276.JPG https://lh4.googleusercontent.com/__...0/IMG_3278.JPG https://lh5.googleusercontent.com/__...0/IMG_3279.JPG https://lh4.googleusercontent.com/__...0/IMG_3283.JPG Also added another radiator to keep temps below 170 or so. Max temp for the R1 motor is 230 or so. I am asking 35k. I have all the paperwork on hours/labor, parts. I also have videos and over 289 photos documenting the build/transformation. This thing was NOT an easy car to build. But it draws crowds more than a live real elvis come back to life on hollywood. blvd. I have way more invested :( Some vids driving around town: http://www.youtube.com/watch?v=8uKC4A1jJs8 http://www.youtube.com/watch?v=axivWKdRCj4 http://www.youtube.com/watch?v=RBF3KJ4w_CI http://www.youtube.com/watch?v=dPfr4nynpDA] It behaves well below 7k. Above you better have testicles of steel. It pulls harder than any small car I've ever been in. And the sound is just glorious. Current Changes from the pictures: The hood has been debadged, R1 emblem added to trunklid, black plate CA plates. inquire at daign2002 at gmail.com |
That is amazing. I cant imagine how fun that would be to drive on some good twisty roads. Good luck with the sale.
awesome mini.
