Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > British > Mini Cooper
Reload this Page >
SneedSpeed R56 Trailing arm swap for R53
Notices
Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Old 10-19-2016, 11:19 AM
sneedspeed is on a distinguished road
Want to lose some weight off your R53 MINI without removing the interior? Then the R56 rear trailing arm swap is for you! Replace the heavy stock steel rear trailing arm on your R53 with a lightweight factory aluminum trailing arm from the R56. Saves about 8 pounds per side. Our kit comes with everything you need to do the swap, including a set of good used R56 rear control arms, new heavy duty wheel bearings and hubs, all bolts and hardware needed and the correct swaybar end links.
ID:	461425   Click image for larger version
Join 6SpeedOnline
Visit our Sponsors
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
