SneedSPeed Mini R53 Stud conversion kit - 6SpeedOnline - Porsche Forum and Luxury Car Resource
Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > British > Mini Cooper
Reload this Page >
Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Old 10-26-2016, 09:12 AM
sneedspeed is on a distinguished road
Your wheel stud and lug nut are the only thing holding your wheel on at 100+ MPH!!
Made in USA for race applications.
These 12mm x 1.5 thread wheels studs are custom made for MINI race applications. They are 92mm total length with 16mm of bullet nose, 51mm of lug nut thread, 10mm of shank and 15mm to thread into the wheel hub. Heat treated with rolled threads and rated at 190,000psi. These wheel studs work with hub centric spacers up to 20mm. Lug nuts use standard 17mm socket for installation. Designed for use in both stock and aftermarket wheels with 60 degree taper. Coated yellow, to prevent rusting and for easy locating on the ground or in your tool box.
Includes 16 lug nuts and studs.
Spec Sheet:
Wheel stud total length- 92mm
Lug nut threaded length- 51mm
Bullet nose length- 16mm
Shank length- 10mm
Thread wheel hub end length- 15mm
ID:	462003   Click image for larger version
Name:	Stud Conversion1.jpg
Join 6SpeedOnline
Visit our Sponsors
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
