Look out Philly! Leo’s 1059whp ALPHA 10 GT-R is on it’s way.
A little while ago Leo contacted AMS to upgrade his bolt on turbo stock engine GT-R to an ALPHA 10 Package http://alphagtr.com/...pha-10-package/. Leo's car has been in several online videos advertised as an ALPHA 9 but in actuality he was running a turbo smaller then we use for our ALPHA 9 kit. None the less it was time for an upgrade and he went BIG!
In addition to our FULL ALPHA 10 package Leo wanted a little bump in power. Rather than pulling the trigger on an ALPHA 12 he added our ported throttle bodies and our prototype intake manifold. The results were AWESOME! In fact it's the highest HP ALPHA 10 TO DATE!!!!
AMS Alpha 10 Turbo System
Balanced and Blueprinted VR38 AMS Race Engine
AMS GT-R Ferrea Cylinder Head Component Package
AMS Alpha Series Custom Camshafts
AMS Alpha 10 Transmission by Sheptrans. Upgraded with Dodson and PPG components
Alpha Race Downpipes
Customer supplied midpipe
Customer supplied 90mm exhuast
AMS Front Mount Intercooler Upgrade
AMS 76mm High-Flow Intercooler Piping
HKS SSQV Blow Off Valves
AMS Alpha Induction Intake Piping
K&N Air Filters
AMS Map Sensor Upgrade
AMS Spec. Upgraded Fuel Injectors
AMS Alpha Series fuel system upgrades
Cobb AccessPORT tuning system
Alpha coolant expansion tank
Alpha ported Throttle bodies
Alpha prototype intake manifold
Peak power was 1059 wheel horsepower on MS109E
Peak power was 832 wheel horsepower on 93 octane pump gas
Peak boost on race gas 30 psi
Peak boost on pump gas 23psi
We had an issue with the RPM pickup on the dyno so I was unable to get a Tq reading on the 1059whp run. I did however post up another lower boost graph for reference.
Leo I hope your ALPHA 10 GT-R is everything you have hoped for and more. Thank you for the opportunity and ENJOY!
K&N Air Filters
Jeez this thing is going to be a beast. Cant wait to go for a ride !!
What turbos are used in this setup? I've heard everything from stock hosuing with bigger wheels to 28s and 30s, was always curious as to what it actually is.
#TeamAIM
#TeamAIM
Every shop uses a different setup. The turbo's used in our ALPHA kits are nothing off the shelf.
The ALPHA 9 uses a Garrett CHRA but we incorporate a custom billet compressor wheel and machined stock housings.
The ALPHA 10 and 12 are full turbo kits. We cast our own tubular Vband manifolds and fabricate all the necessary components necessary to facilitate that level of power.
Below are some CAD images from our engineers on that ALPHA 10 and 12 kits:
Here are some of our first samples for test fitting out of our 3D printer
Then on to our first cast units
Then we heat protect the whole package
As you can see the 10 and 12 kits are much more complex that our 9 that uses larger turbos in the stock housings.
Eric
Eric
Tial SS hot sides - good choice.
#TeamAIM
#TeamAIM
That is just nuts! Hey Leo, congrats and I'm in Harrisburg , pa. you should come down this way. We have a modified slr, lingefelter c6 z06, switzer 997tt, turbo Busa, and my slow gtr. I gotta see this beast in person.
only the best
thanks
thanks
Kai@ELITEMS
Aug 6, 2016 09:50 AM
Kai@ELITEMS
Oct 1, 2015 04:34 PM
Kai@ELITEMS
Bentley
Oct 1, 2015 04:33 PM
Kai@ELITEMS
Ferrari
Oct 1, 2015 04:32 PM
Kai@ELITEMS
Lamborghini
