Lowering module
Old May 7, 2014 | 08:57 PM
CMLXX4S's Avatar
CMLXX4S is infamous around these parts
Lowering module
Has anyone installed a manual lowering module on their Panamera... Accuair/KW DLC/etc?
Old May 8, 2014 | 01:45 AM
tonyep's Avatar
tonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of lighttonyep is a glorious beacon of light
I have Renntech DLC installed on my PTT.
Old May 8, 2014 | 06:08 AM
b911s's Avatar
b911s is infamous around these parts
I just installed the Renntech module on my 14 GTS. Installation of the actual module was pretty straight forward with the swapping out of the 4 wires from the Porsche harness to the Renntech. The biggest PITA was getting to the control module located in the left rear of the trunk. Once installed, the Renntech software is very simple to use and very adjustable. Make your adjustments, send the file to the module and bingo, your car is lower. The cool thing too about the system is that it raises the car back to stock height once you reach 30 MPH to avoid any unnecessary tire wear and no need for realignment. You can adjust this setting as well and pick at what MPH the car will return to stock height or eliminate the feature all together.
Old May 8, 2014 | 08:59 AM
CMLXX4S's Avatar
Awesome! Sounds like Renntech is the way to go - Thx for the feedback.
Old May 9, 2014 | 01:34 AM
rufus1972's Avatar
rufus1972 has a spectacular aura aboutrufus1972 has a spectacular aura about
For me it's the kW dlc ....you can see my post on the forum for the details...
Regards
Pascal
Old May 9, 2014 | 02:03 AM
rufus1972's Avatar
Final result with kW dlc on my GTS,show mode only when car is stopped
adnanm3
Nov 22, 2023 02:43 AM
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
dgreen78
Feb 29, 2016 11:28 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
kensworth
Cayenne 955/957
Sep 9, 2015 05:45 AM
