Seat Bolsters not working
Hi all
The seat bolsters on my PTT have stopped working. The ones at your hips / thighs & back of knees.
The back support ones work fine. (Lower middle & upper) and the rest of the seat adjustments work fine. Also the seat heating work fine too.
I have checked all fuses and they are fine.
It has stopped working on both driver & passenger. Is there any suggestions from members here who have gone through the same thing?
I cant figure it out?
Also, another question regarding the homelink in the overhead panel. I have the 3 buttons there, but how do i know if my car is optioned with homelink? I have tired the resetting procedure, but no light appears. Even if the car didint come optioned with it from factory, are the buttons still there? Or is mine not working too?
Hi all
Regarding homelink- if you have the buttons you have the functionality. Do any of the buttons light up when you press them? (vehicle needs to be "on")
Thanks for the reply. Yes it's strange regarding the seats. Are they run off air from the suspension compressor? Because it happened after I got the car back from having the valve block and compressor replaced.
Regarding home link nothing at all lights up when pressed.
Hi,
If it has to do with electrical pb then the heated seats should be out too because bolsters and heat are linked to the same fuse. Could you confirm ?
As Adaptive Sport Seats are available on many Porsche models without air suspension, I can guess with near 100% certainty that they are not in any way connected to your suspension system. However, it's not uncommon for a machanic to inadvertently bump or dislodge a wiring connector as they work on a car. I think seat problem is a coincidence that it occurred after your suspension repair.
This is still baffling me. I am going to spend some time on it this week, and report back my findings.
greenshoe
06-10-2019 10:49 PM
