GTS rear brake shim removal
The rear brakes on my 2014 have a shim with a cylinder attached. The cylinder has O-rings and slides into the caliper pistons. The shim/cylinder assembly appears to be bonded to the back side of the brake pad. Can this assembly be reused or should a new assembly be purchased ($25 per side)? It's not clear i can remove the shim without damaging it. These are the original brakes.
I was able to separate them from the pad by very carefully forcing a razor from a utility knife between the pad and shim. The new pads have adhesive already applied to bond with the shims. I agree it would be easier to replace them but at $25 per pad (100 total) they would cost as much as the pads. I would imagine some people don't reinstall them since noise is not a concern.
I can't speak with certainty re the Panamera pads, but no pads for any of the 911s I've owned came with the Shim/puck assemblies. They've always been sold separately. Their purpose is to keep the pads from vibrating and lowering the possibility of brake squeal. On some of my 911s, I'd remove the shims in order to install track pads. I often didn't use them when I'd put the street pads back in and had no squeal. However, they're there for a reason, it's up to you to decide. The can be reused if you can get them to stick to the pack of the pads.
