cold start stuttering issue
on cold starts the car will stutter and sometimes throw a CEL and PSM failure.. scan tool says cylinder#2 misfire. already replaced plugs and coil.. has anyone else had this problem, if so..any solution... car no longer under warranty.:confused:
I had similar problem.
Cyl #:X (cant remember exact one, lets say it was CYL 1) Code was CYL 1 Misfire. First thing i did was replace all plugs (needed to do it anyway) Went away for a day, then came back. Car was shuddering. Still Cyl 1 misfire. So i know it wasnt plugs, next was to try coils. Instead of replacing all coils, i move the Cyl 1 coil to cyl 2 and vis versa. The fault followed and now i had fault in Cyl 2. Bingo, coil pack. Fixed! |
************* UPDATE**********
Replaced the spark plug and coil on cylinder #2... drives great now.. |
