Front End Creaking - Parts Replaced
#46
googleknowseverything, did you try at least to google what is visible on the package ? seriously !
https://www.google.com/search?rlz=1C...iz.weHZ59DHaQ4
Market .. ))) I better will spend my time for another things market, much more profitable, I hope you understand me.
#51
I have a diy thread on upper control arm removal. Prolly could help. Not difficult actually. Seach my name and upper conrol arm Diy.
#53
#57
yes, the same as for Q7, Toureg... as written on site
how it is in reality I can't confirm ....
#58
Yes the bushings will transfer more noise and vibration than rubber bushings (they even mention this on their website)- they also need to be greased regularly or they will squeak
#59
I think that seller just protects himself about the noise... because these are made from soft polyurethane, and it is only 4 of them in the car, and in control arms, not in sub-frames ....
regarding greasing they has to be properly greased during installation, I can't imagine how you could grease them later .... I have other cars with all bushings from polyurethane,
never greased in 7 years - no squeak ...
https://www.powerflexusa.com/why-poly : "By correctly engineering the polyurethane compound, bushings can be made 25-30% stiffer than new rubber items but with exactly the same noise absorbing properties."
P.S> https://www.powerflex.co.uk/fitting-guides
