5 simultaneous faults?!!!!
Old 04-27-2017, 03:59 PM
Unusual12b's Avatar
Unusual12b is an unknown quantity at this point
Has anyone got ideas? My 2013 panamera turbo has done this several times. When I power off completely and restart, it goes away. No ODDB code.
Check engine
fault all wheel drive system
fault transmission
start stop mode deactivated
PSM failure
It then goes into a mode that is a bit rough engine running, and extremely delayed and slow shifting. Goes away when I shut down and restart.
Anyone???
replacing the coils fixed it. Thx everyone!
Old 04-27-2017, 04:48 PM
Shattuck's Avatar
Shattuck is an unknown quantity at this point
I had the same thing. The dealer replaced some engine coils. So far it hasn't come back.
Old 04-27-2017, 11:32 PM
allroadusa's Avatar
allroadusa has a spectacular aura aboutallroadusa has a spectacular aura about
Same thing here. 2 coils were failing.
Old 04-28-2017, 01:49 AM
amgpan's Avatar
amgpan is an unknown quantity at this point
Same for me
1 Coil
Old 04-28-2017, 02:27 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
bad or weak battery will cause all kind s of weird stuff on many cars likes these...
Old 04-29-2017, 07:10 AM
RSogi's Avatar
RSogi is an unknown quantity at this point
Same here. 3 coils already #2#4 and #5.
I had OBD codes and I could identify them.
Old 05-02-2017, 01:11 PM
esiegal's Avatar
esiegal is an unknown quantity at this point
2010 4S with 41K miles. Just had the same issue this past weekend. My mechanic is starting with the coils and plugs. Waiting to see if this solves the issue.
Old 05-02-2017, 07:00 PM
Unusual12b's Avatar
Thanks all! Replacing the coils solved it😀
Check engine
fault transmission
PSM failure
Anyone???
replacing the coils did the fix. Thx
Old 05-04-2017, 11:06 AM
robhamster's Avatar
robhamster has a spectacular aura aboutrobhamster has a spectacular aura about
My 2012 P4S had those errors backin 2014 at 19,000 miles. Hoping it was the coils, but Porsche replaced the entire engine. I never got the full story from Porsche but they think scored cylinders were the ultimate cause.
Good to see yours was fixed easier than that.
Old 05-31-2017, 10:21 PM
esiegal's Avatar
Can you tell me the channels you went through with Porsche? I'm having the same issue on my 2019 P4S. I'm at 39k miles and my mechanic is telling me I need to replace the engine. I'm wondering if I should reach out to Porsche?
Old 08-11-2019, 11:05 AM
mustangsrmine's Avatar
mustangsrmine is an unknown quantity at this point
Exact same issue just happened with my 2010 4s. Coil 4 failed, replacing all 8 anyway.
Old 08-12-2019, 07:44 AM
XLR82XS's Avatar
YES. Good info for owners to keep in mind.
Old 07-07-2021, 03:06 PM
Mofongo's Avatar
Mofongo is on a distinguished road
I just had this same thing happen to my 2013 GTS. OBD said it was cylinder #1. Mechanic swapped coils with #2, and the problem went way (so far). Conclusion was that there must have been a loose connection that was mitigated when they did the swap.
