Lowering springs installation DIY?
Old Sep 9, 2017 | 11:54 AM
ih82lose's Avatar
ih82lose is infamous around these parts
I'm looking at getting some lowering springs for my 2010 4s and was wondering if anyone has seen a DIY write up on the installation of springs, or shocks/struts for that matter. I've done the job before on several other porsches and German cars, but usually there was some DIY write up to give tips, such as what needs to be loosened on the front suspension to be able to get the strut removed, or if there is some way to remove the springs from struts without pulling the strut.
Any links, videos or tips are appreciated!
Old Sep 13, 2017 | 08:04 AM
OEkun1's Avatar
OEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura aboutOEkun1 has a spectacular aura about
It is DIY and is like any other spring swap. You will need to pull the struts to do it, but once you get into it, its fairly easy. I did mine and can tell you that its fairly straight forward.
