'10 panamera auto lock and oil level question
Old Nov 18, 2017 | 11:47 PM
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
hey just had 2 questions
1) on the 2010 with the Porsche entry and drive option, if you are to forget to lock the doors with the porsche key when you are exiting the vehicle will it automatically lock the doors after a certain amount of time?
2) also how fast does oil get consumed on these vehicles, already had a minimum oil warning once on this car and ive only had it for one month, had 0.5 L topped up and now there are 2 bars above the minimum line....how long should that last before needing to be re topped up?
thanks
Old Nov 19, 2017 | 05:50 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
#2. Each vehicle will be different. Most probably use very little to no oil. Keep an eye on the oil level until you see how much it will use. I have a 15 an use no oil between 10K mile oil changes. Every once in a while you see a car that uses significant oil amounts. Keep in mind maybe you have a small leak and it s not burning oil if it continues.
Old Nov 19, 2017 | 07:09 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
On my '14 4S the doors do not auto lock (at least they never have yet).
I do have the entry and drive option.
Regards,
Chuck
Old Nov 20, 2017 | 02:52 PM
XLR82XS's Avatar
Regards,
Chuck
Same here. 2011 PTT.
Old Nov 25, 2017 | 12:16 AM
newporsche's Avatar
5 Year Member
it seems like the oil level on mine drops quite quickly, about a few weeks of driving daily and the oil level goes down one bar (which i think is like 0.25litres of oil?) Is this happening with others? is this normal?
Old Nov 27, 2017 | 04:12 PM
Ride4Life Rossi's Avatar
Ride4Life Rossi is infamous around these parts
I find it depends on how hard I drive, when I drive it very hard it tends to burn oil a bit nothing crazy
Old Nov 28, 2017 | 02:35 AM
newporsche's Avatar
5 Year Member
i had 1/2 L/quart added 3 weeks ago and already its gone down to the minimum level again! is this excessive?
Old Nov 28, 2017 | 09:43 PM
newporsche's Avatar
5 Year Member
lost aprox. 2 lines on the display (0.5 quarts) over 500km, sound normal? possible engine issues?
