panamera SE hybrid 2014. Audi 3.0 TFSI 40,000 MILES MAINTENANCE> WHAT TO DO?
Hi,
Do you have the complete list of items to be done for the 40, 000 miles maintenance check?
I want to be sure I am NOT forgetting anything.
Appreciated
Appreciated
HI, REPLACEMENT OF PDCC RESERVOIR YES OR NO???
Yes)
Maintenance is :
Wiper System
Horn
Tires and Spare
Read Fault and Reset system
Light Check Adjustment
Battery venting hose
Under Panels. Visual
Steering Gear. Visual Inspection
Tie rod Joints. Play and dust bellows
Axle Joints. Play and dust bellows
Exhaust System. Visual for Leaks and damage. Check Engine mount
Fuel Lines and connections
Coolant. Levels
PDCC and Power Steering
Remote Control, Park assist, Parking brake, PSM switch, AC etc
Brake Lines. Visual
Brake Hose. Visual
Drive Shafts. Visual Inspection for leaks
Radiator and air intakes. Visual Inspection
RESET THE MULTI PURPOSE DISPLAY
OIL CHANGE
REPLACE SPARK PLUGS
REPLACE SUPERCHARGER BELT
AIR FILTER
CHANGE BRAKE FLUID FLUID FOR CLUTCH
Yes)
Maintenance is :
Wiper System
Horn
Tires and Spare
Coolant. Levels
Brake Lines. Visual
Brake Hose. Visual
OIL CHANGE
REPLACE SPARK PLUGS
AIR FILTER
GMP Performance
Audi
Dec 16, 2013 09:17 AM
