panamera turbo caliper brake pad guide pins
Does anyone know where I can get the PN for guide pins for brake pads, which are screwed into the calipers?
They are the pins that go into the holes for brake pads on front. if you know where they can be bought, I will appreciate the links too. Thanks. |
These are not the pins I am refering to.
these are guide rods to slide caliper away from rotor during service. i am refering to brake pad guide pins on which brake pads slide when braking. they are installed into the caliper itself. 4 per caliper. |
I am talking about the pad guide pins in the pic:
https://cimg3.ibsrv.net/gimg/www.6sp...811159f994.png |
Ciaka,
You can get the part # from your local Porsche dealer, buddy. |
Not sure they sell those parts separately. But if you are looking for part numbers, you can download the Porsche catalog (with schematics) here: https://www.porsche.com/usa/accessor...originalparts/
It is not in the catalog. Already have two.
Hi Ciaka,
How do you remove the pad guide pins you show in the picture? Do you need to replace the pad guide pins when you do the new brake and rotor? Thank You |
On my cayenne turbo, these pins have a PN assigned and you can replace if over worn.
On my panamera turbo, I have been looking for these including at dealer. Not finding anything. Dealer told me these pins do not get removed, and you only clean them. The pins have an E-torx screw on outside of caliper, that you would unscres to get pins replaced. I see these bolts on both cayenne and panaera. However dealer was stating not replaceable. So as of now, i still do not have the pins, and will be cleaning when I install new brakes sometime soon (waiting for good weather and time to do this).
Originally Posted by dougcayenne
(Post 4758891)
Hi Ciaka,
@ciaka :
I know this is an old post, but Suncoast was kind enough to add them to their website after I inquired about my 958 / 92A: https://www.suncoastparts.com/product/wht008689.html Still waiting to receive them, but if they are indeed what they proclaim to be, they will require a 10 Point Brake Caliper Socket to remove (available on Amazon). Has anyone had any experience removing/replacing these? I did my first brake job recently and would have loved to replace them instead of having to clean them in place (and then properly clean the old ones for next brake job). |
