Brighter reverse lights?? 2016 Panamera GTS
Hey all,
It's hard to see when I backup at night in my 2016 Panamera. Are there any brighter reverse lights to use instead?? |
Would like to know this too - I'm sure I've seen something about it on the forum though. It should be just as simple as a bulb swap for a bright white LED I'd think (perhaps even just a 194?)
I tried taking mine apart to replace w/ an LED bulb and it did not appear to be serviceable. License plate bulbs super simple, but I would also like to upgrade my reverse lights. I found a thread where a vendor claimed it could be done easily but that wasn't my experience.
I'd be interested in more light as well, the 2010 factory part # is 999 631 250 91
parts images make it look like a rather unique piece (of course) as seen here https://www.gaudinporscheparts.com/o...b-99963125091/ seems it was used in a number of models - might be able to find an answer in some of the other groups found these: https://www.carid.com/2010-porsche-p...bs-403817.html bit pricey, claims to fit all 970 models |
Wanted brighter reverse lights too.
User manual indicated that it would be a simple bulb swap after removing the taillight assembly, and then removing the cover behind the reverse light bulb. Bought a pair of Canbus error free LED white bulbs and removed taillight. Like skiracer13, found out that the reverse bulbs could not be removed. There is a permanent cover where the manual says should be a removable cover. https://cimg4.ibsrv.net/gimg/www.6sp...2156383701.jpg 2013 GTS |
Interesting and rather odd, will have to take a look at mine as well, suspect I'll find the same.
Originally Posted by 970gts
(Post 4758169)
Originally Posted by skiracer13
(Post 4758241)
Yep, I got to that same point and realized that I was getting in over my head. Sure wish there was an easy way - I have an assortment of LED bulbs to try but can't access the socket at all.
Originally Posted by LouvreLife
(Post 4758484)
Which LED bulbs do you have?
weird, just popped mine (2010 4S, produced 11/2009) and I have the backup light access hatch, I wonder why there is so much variation?
found a video about it, they mistakenly take out all 3 torx screws, you only need to remove the middle one. (T-25) https://cimg7.ibsrv.net/gimg/www.6sp...71236528c9.jpg |
Originally Posted by DogWood
(Post 4758780)
found a video about it, they mistakenly take out all 3 torx screws, you only need to remove the middle one. (T-25) https://cimg7.ibsrv.net/gimg/www.6sp...71236528c9.jpg Any chance you can post the video you found? Maybe I'm missing something... |
found them here:
https://www.carcarekiosk.com/video/2.../reverse_light |
(Post 4758834)
found them here:
Maybe after the 2010 (or later) model year, Porsche made the reverse light non-serviceable?
Or depends on whether you have a Base, S, GTS or Turbo? Thought a possibility was that the reverse lights might be unserviceable because they were already LED...… wishful thinking, they look like they're incandescent. Can't think of a rationale why Porsche wouldn't allow the reverse lights to be changed out. |
(Post 4758863)
