DIY:Porsche logo door courtesy light swap
#35
Mine is 2013 model should as the same as yours. What do mean you had bend the pins. Which pins? Then if you want to put the original back later on will be ok? Now I am worry a little bit. I don’t want to change or damage anything.
Do they come with LED bulb?
#37
#38
the pins on the light that plug into the wire harness, they where just sticking out a bit crooked and the plug wouldn't slide in - simple to just push them over a bit with a small screwdriver.
Nothing to worry about
#39
ok then. Did you say the LED bulbs comes with it or I need to buy them separately.
#42
Did the back doors, ordered from a different vendor who's add showed a circle around the logo, lights I got don't have that, bit disappointed
whoever the logo is a bit bigger and the gold is more gold colored.
overall I'm happy, nice inexpensive bling
top backdoor, bottom front
