porsche panamera 2010 does it use AGM battery?
hey all i need to recharge my 2010 panamera, the charger has options for a 12v AGM battery and a 12v regular battery, does anyone know what if the OEM battery for the Panamera is a 12v AGM battery?
Yep AGM is what you want
anyway i can confirm it before connecting it to the charger/maintainer all winter?
OEM is AGM, pop the trunk and look - should be labeled as AGM
ok ill check if its actually labelled...battery is in rear trunk?
Charger connections are under the hood, battery is under the panel in the trunk
ok thanks
