aux reverse light - stripped torx head
Need brighter reverse lights. Unfortunately I have taillights where the cover to change out the reverse light is sealed, so I can't change out the bulb. Bought a couple of LED floodlights from Oznium to augment the existing reverse light. Installed them on either side of license plate frame and all set to wire it up to the taillight electrical connector. Screw (T25?) holding the taillight in place was so tight, I ended up stripping the corners of the torx head. Did the same to the opposite side. Anyone have any suggestions hold to remove the stripped screw so that I can remove the taillight and wire the auxiliary reverse lights up?https://cimg0.ibsrv.net/gimg/www.6sp...fc7ab6fa05.jpg
https://cimg1.ibsrv.net/gimg/www.6sp...1836665539.jpg https://cimg2.ibsrv.net/gimg/www.6sp...63496c1083.png |
Originally Posted by 970gts
(Post 4785911)
https://cimg1.ibsrv.net/gimg/www.6sp...1836665539.jpg https://cimg2.ibsrv.net/gimg/www.6sp...63496c1083.png Get a set of those stripped screw removers, basically a cutting head that digs into the metal and reserves it out (forget the name), but have had to use mine many times. |
Bob vila to the rescue
https://www.bobvila.com/articles/how...rew-extractor/ |
Many thanks for the advice. Got a screw extractor kit from Harbor Freight, $10. Carefully followed directions and screw is out. Replaced it with a stainless steel one with a beefy hex head (screw is M6). Will splice LED wires to taillight connector and post pics of how it turns out.
