2006 Lotus Elise – Polar Blue – 48.5k miles – Michigan
2006 Lotus Elise – Polar Blue – SOLD
Year: 2006
Make: Lotus
Model: Elise
Price: $34800
Mileage: 48520
Color: Polar Blue
Location (State): MI
Transmission: Manual
Drivetrain: Rear Wheel Drive
Factory Options:
Touring Pack
Hard and Soft Tops
Star Shield (since been replaced with much better SunTek Paint Protection Film)
VIN SCCPC11106HL31723 (clean title, clean carfax)
For sale is my 2006 polar blue Elise that I bought in March 2014 with 29,000 miles. This was/is my dream car that I obsessed over since the S2 Elise was first sold in the States in 2004. I spent years searching for an Elise that matched exactly what I was looking for (I specifically wanted the rare polar blue color which was only available in 06/07 – Only 35 polar blue Elises for the US in 2006 and even fewer in 2007). I tend to rotate through cars on a pretty regular basis, and the Elise is by far the longest I have ever owned a car. I am still hesitant about selling, but I’m looking to try something else and would need to free up the space first.
The Elise now has 48,5xx miles and has been meticulously maintained by myself and the prior 2 owners. Always garaged, and stored on hub stands with a Battery Tender and Stabil during the winters. I have every service/maintenance record or receipt from the original owner, including the window sticker and transaction documents from The Collection dealer in Florida, and tons of receipts from my ownership. The previous owners did not track the car. During my ownership, I have done quite a few reliability and performance modifications, and did about 4-5 track days per year. Oil changes and brake fluid were done every couple track days. Again, I have documented everything done to the car and have all receipts saved in a (large) folder. I have most of the original parts that can be included, as well as extra brake pads and rotors.
Link to for sale ad from last owner: https://www.lotustalk.com/forums/f94...r-blue-205754/. Adding up my receipts, I have put about $20k into upgrading the car since then. You can certainly buy a cheaper Elise, but IMO I have done all the best upgrades to make a great reliable track day car that I still enjoy on the street.
Asking
I would be willing to convert some parts back to stock to lower the price a bit:
- Subtract $1,800 if I remove the Penske coilovers, and replace with original stock Bilsteins
- Subtract $500 if I remove the Tillett seat, harness, and harness bar, and replace with original
Modifications:
Done by first owner:
- De-snorkeled intake
- Lower motor mount inserts
- Quarter turn fasteners for underbody panels
Audio
- Alpine CDE-HD138BT headunit
- JL Audio C2-525X Front speakers
- JL Audio C2-600X Rear speakers
- Sector 111 Flex Co Aluminum Lightweight Blue Radiator (April 2013)
- Sector 111 radHOSES (April 2013)
- Sector 111 Bootie
- BWR Ultimate Cup Holder
- BWR Front License Plate Mount (I don’t need it in Michigan)
Powertrain
- BOE Torque200 Tune
- Top Speed Pro 1 Exhaust
- BOE TOC baffled oil pan
- V2 Baffled Fuel Tank
- ACT HDSS Clutch and Pressure Plate with ARP bolts (replaced at 34,600 miles due to faulty pressure plate – original clutch disc was in perfect condition and can be included with sale)
- MWR Forged Lightweight Flywheel with ARP bolts
- LETSLA shifter
- BWR Penske Single Adjustable Shocks with hand **** adjusters and 500F/700R Springs
- V2 Steering Arms and shims
- SSC rear toe links and brace
- StopTech SS brake lines
- DBA 4000 rotors
- Carbotech XP12 front and XP10 rear brake pads
- Motul RBF600 brake fluid
- Carbon fiber front splitter (touched up paint scrapes from previous owner on underside of clam before installing)
- Carbon fiber Reverie diffuser
- Black LSS wheels with Black/Silver Center Cap Emblems and Black Lugs Bolts (replaced original silver base wheels)
- Toyo R888R tires in OEM LSS sizes
- Black/Silver Nose Badge
- Black “LOTUS” and “Elise” rear badge decals
- Section 111 Folding Front Tow Hook – plastidipped black
- Sector 111 DBWpedals
- Sector 111 Silver Micro Mirror
- Hard Top Headliner replaced with Alcantara
- Black/Silver Steering Wheel Badge
- Tillett B6F Carbon Fiber Driver’s Seat
- BWR Harness Bar 2.0
- Schroth Profi II 6 Point Harness for Driver’s Seat (stock belt still installed and usable)
- Sector 111 Sys 6 Pack seat/harness attachments
- Cut new key for Fubrication Unikey fob
- GRP Hydraulic Trunk Lid Strut (replaced original prop rod)
- V2subFIX
- Deka ETX20L battery with NCI bracket
Maintenance:
Purchased new on 10/18/06
1015 miles, 11/8/06 – Oil Change
3930 miles, 4/23/07 – Oil Change
6030 miles, 10/1/07 – Oil Change
8610 miles, 7/3/08 – Oil Change
11,847 miles, 8/5/09
- Replaced A/C relay module under warranty
- Replaced starter button light under warranty
- Resealed soft top trim under warranty
- Oil Change
8/21/09 – Replaced rear tires with Yokohama AD07
15,252 miles, 7/19/10 – Oil Change
17,925 miles, 6/3/11 – Oil Change
11/21/11
- Replaced front and rear brake pads with StopTech Street Performance pads
- Flushed and bled brake fluid with ATE Super Blue fluid
19,935 miles, 12/28/11
- Flushed coolant
- Both cam lobes found to be worn – replaced both cams and gaskets
- Replaced spark plugs
- Replaced rear tires with Yokohama AD07
20,759 miles, 6/18/12
- Pre-purchased inspection completed – no issues found
- Oil Change
Second owner had the car from 7/13/12 until I purchased it on 3/21/14 with 29,005 miles (second owner did not save receipts)
April 2013
- Oil line recall done
- Windshield replaced due to small crack
- Battery replaced with Optima RedTop 8020-164
30,162 miles, 4/22/14 – Oil Change
30,270 miles, 5/1/14 – Four Wheel Street/Track Alignment
6/7/14 – Professional interior and exterior detail
8/23/14
- Balanced set of Black LSS wheels and Dunlop Direzza Star Spec Tires to replace original wheels and tires
- Replaced front and rear brake pads with Ferodo DS2500
- Flushed and bled brake fluid with Motul RBF600
32,502 miles, 9/12/14 – Track inspection completed – no issues found
32,939 miles, 9/27/14
- Replaced front and rear rotors with DBA 4000
- Oil Change
34,600 miles, 3/31/15
- Flushed and bled brake fluid with AP Racing PRF
- Oil Change
- Transmission Fluid Change
- Full track setup done by V2 Motorsport (alignment, corner balance, and ride height)
- Reinforced rear diffuser attachments with V2subFIX
35,224 miles, 5/2/15
- Replaced low-beam and high-beam headlight bulbs with Osram Silverstar Halogen
- Replaced front parking light bulbs with Osram LED
- Replaced license plate bulbs with Osram LED
35,430 miles, 5/16/15 – Replaced air filter with ITG filter
36,211 miles, 7/10/15 – Oil Change
36,350 miles, 7/19/15 – Flushed and bled brake fluid with Motul RBF600
38,238 miles, 9/11/15 – Replaced front brake pads with Ferodo DS2500
38,680 miles, 9/26/15 – Oil Change
39,035 miles, 10/10/15 – Replaced GRP trunk lid strut (original gas strut lost pressure)
39,560 miles, 5/7/16
- Oil Change
- Transmission Fluid Change with Redline MT-90 and Synchromesh mix
39,731 miles, 5/21/16 - Flushed and bled brake fluid with Motul RBF600
41,336 miles, 7/10/16
- Oil Change
43,897 miles, 4/10/17
- Replaced front brake pads with Carbotech XP12
- Replaced rear brake pads with Carbotech XP10
- Flushed and bled clutch and brake fluid with Motul RBF600
- Oil Change
- Replaced four tires with Toyo R888R
43,979 miles, 5/14/17 – Replaced spark plugs with NKG BKR6EIX-11
45,510 miles, 11/8/17 – Replaced original Star Shield with SunTek Paint Protection Film from Chuforia Graffix
- Full coverage hood and mirror kit (including access panels)
- Bumper kit (including license plate area)
- Full coverage door sill and rocker panel kit
- Rear impact area kit
45,550 miles, 11/14/17
- Repaired loose rivets in mud flaps
- Replaced loose exhaust clamp
45,583 miles, 3/30/18
- Replaced left front tire with new Toyo R888R due to nail
- Replaced battery with Deka ETX20L and NCI bracket
- Oil Change
- Reverse taillight bulbs replaced
46,142 miles, 5/22/18 – Bled brake fluid
47,374 miles, 9/9/18
- Oil Change
- Replaced BOE oil pan drain plug and o-ring
47,946 miles, 3/23/19
- Replaced thermostat and gasket
- Filled and bled coolant with Peak Global Lifetime
- Replaced serpentine belt
48,146 miles, 5/26/19 – Flushed and bled brake fluid with Motul RBF600
You have good taste. I have the same garage. Though I doubt I could part with either my Elise or my 996tt. My Ducati will however be up for sale shortly.
Based on the apparent condition and mods your Elise is very well priced indeed. Someone is going to get a tremendously fun car.
equ
08-09-2017 08:34 PM
