G50 3.2 Fresh 15k G/O Repaint.
Year: 1989
Make: Porsche
Model: 911
Price: $51911
Mileage: 159000
Color: Guards Red
Location (State): NJ
Transmission: Manual
Drivetrain: Rear Wheel Drive
Manual 1989 Guards Red over Oyster Beige 3.2L Carrera G50 911 with 159k original miles. The car just completed a thorough technical and aesthetic overhaul. The paint was showing its age with the typical burnt orange fade. A $15,0000 glass out show quality repaint, all new body seals and rubber accessories make this one of the nicest G50 cars anywhere. The paint is better than OEM.
Over $7000 worth of work was completed in the last 500 miles at one of the best Porsche specialists in the northeast. They went over the insides of the car with the same OCD approach the painter did to the outside. There is not a single rattle or squeak present anywhere. I've driven countless air cooled 911's and this is one of the tightest. It feels like it has 59k miles just with WAY better paint than any original car.
Mechanically the car is a 10/10, Exterior is 10/10, Interior is 8.5/10. Every mechanism, switch, and button is new and works as it should.
A new clutch & flywheel, new brakes, brake shoes and rotors, and a freshly rebuilt gearbox mated to a freshly re-sealed engine mean this car is ready to give its new owner thousands if not tens of thousands of worry-free miles. The electronics, including all wiring, light bulbs and fuses have been replaced with new OEM parts.
With the price of 964's going through the roof the last year G50 3.2's are the air-cooled cars are the most desirable providing the greatest combination of classic and modern. There are lower mileage 3.2's available but I would put this car up against any of them. You will be hard pressed to find a better example. More details below and full photo album available HERE:
The Good: No expense spared in bringing this 911 to Weissach standards.
- 159,000 original miles.
- Clean Carfax, no stories and service records
- Spent most of its life in the south. Not a fleck of rust on the car.
- No leaks from the freshly re-sealed engine. Compression test in the normal range on all cylinders.
- Never tracked. Mainly highway miles.
- RARE oyster beige interior color
- Carrera Spoiler with new rubber.
- Like new Fuchs wheels
- New professional glass out repaint and all new seals. Receipts available.
- New rubber moldings and bumper pads throughout.
- >7k worth of recent work from a Porsche specialist.
- No sag in the headliner or sun visors
The Bad:The interior needs a little work. I see this as an opportunity for the buyer to make it theirs. Interiors are super personal. Some like sport seats others like tartan inserts some like OE some like Momo Prototipos or coco mats. etc.
- 1 crack in the center of the dash.
- Leather seats and armrest are a bit worn.
- Original floor
- mats (not pictured) are tired and could use replacing
- The exhaust tip has a small scrape from a steep driveway.
Recent Technical Overhaul Breakdown Below: Last 500 miles of work done by Protosport. Detailed Service Records available: summarized below:
- All fluids changed Oil, transmission etc.
- Rear axle boots
- CV boot kit
- Rear brake discs
- Rear calipers
- Brake shoes all around
- Flush and bleed brake fluid
- Shifter rebuilt w/ new bushings
- Ball socket replaced
- New Clutch + flywheel installed
- New Oil Seals, engine temp sensor, oil pressure switch and breather hose
- New wiring harness after a repaint and full electrical review
- New window switches
- All lights replaced
- Windshield wiper pump replaced
- New rocker caps installed
- All new rubber bumper pads
- Radio Repaired
- Odometer repaired
Squerly
12-16-2004 07:09 AM
