93 RX7 LS1/T56 Red/Tan $15k
Old Jul 19, 2008 | 07:57 AM
canadaisintexas's Avatar
canadaisintexas is infamous around these parts
Price: $15,000 firm
Contact INFO: GOODIN.ROB@GMAIL.COM
Zip: 27587
Milage: 126,400
Clean title
Vintage Red/Tan Touring model
Installed Parts Summary:
Mounting:
Full Hinson Super Cars mounting kit
Engine:
2001 Ls1 w/ apprx 20k miles & good compression #'s
New GM head gaskets and head hardware
BBK 80mm Throttle Body
PFS Catback exhaust
VDO Oil pressure gauge
Transmission:
Stage 4 T56 w/ less than 100 miles from T56rebuilds/sixspeedsinc.com
Pro 5.0 Short Shifter
Steeda Tri-Ax Handle
Fuel:
Walboro 255 fuel pump
6 AN Braided Earls fuel line and fittings
Aeromotive A-1000 FPR w/ pressure gauge
Cooling:
'86 Corvette Radiator
Ford Taurus Electric fan
New 180 degree thermostat
Exterior:
SSR GT3 Wheels
'99 Spec tail lights
Kaixxen HID headlights
Michelin Pilot Sport PS2 Rear tires (70% tread life)
Other:
Sony Head unit w/ 10 Disc changer
Hinson Speedo correction box
Uninstalled Parts:
VDO Water Temp Gauge
H3R.Com B355T Halon 5lb fire extinguisher & Bracket
What the car needs:
Speedo box needs to be calibrated
exhaust section between exh. manifolds and cat-back (the area where you would install either a cat or a Y-pipe)
Wiring needs to be tidied up
Electric fan needs to be wired (wires are in place just need connecting
Lower radiator brackets need to be fabbed and installed, they aren't needed as the top ones are pretty sturdy however for peace of mind its a good idea
Passenger footwell interior needs to be reinstalled and the wiring/ecu tucked away
Oil pressure gauge needs to be permanently mounted as it currently just sits on the center console
new drivers door pillar plastic as the clips on the old one broke off
About 5 engine bay wires need to be replaced that have melted
The car has working PS but No A/C however the A/C compressor is still installed which should make it easier to make the A/C work.
The paint is in top condition as the previous owner had the car repainted however the front bumper shows pock marks from little road rocks.
Note: the PFC does not come with the car that is an old interior picture with the PFC still installed.
Video of the car running and driving a few days prior to the fire: 2008039.flv - Video - Photobucket - Video and Image Hosting
The Fire: There was a small fire this past wednesday, the GM Quick disconnect used to connect the Earl's lines to the stock GM fuel rail is a real POS part and popped off while driving the car, the fire lasted 4 - 5 seconds max before the lack of fuel (I cut off all power) extinguished the fire before I got to it. I HIGHLY recommend replacing this fitting with a screw on type.
I have the entire incident on video as I was driving the car to create another much longer video for the for sale ad. I am willing to send the video to who proves they plan to buy the car and actually have the funds to do so.
Thanks for your time,
Rob
Old Jul 20, 2008 | 09:16 AM
itsfast's Avatar
itsfast is infamous around these parts
Very nice ride and equally as tempting to buy since the Hinson Super Cars crew are local to me.
These cars can be real beasts.
GL with the sale.
Old Jul 23, 2008 | 06:24 AM
Lots of interest, back to the top
Old Jul 23, 2008 | 10:41 PM
chapel's Avatar
chapel is infamous around these parts
classic
Glasgo
Nov 30, 2015 02:37 PM
Luciddaydream
Oct 15, 2015 07:33 PM
JWrightPNH
Oct 13, 2015 01:09 PM
feeltherush
Oct 7, 2015 08:32 AM
fjwheeler
Sep 19, 2015 10:56 AM
