FS: 2002 620hp 3.4L Supercharged E46 M3 Imola Red/Black - $42500
Please direct all inquiries regarding this ad to ronnie0738. Thank you.
2002 E46 M3 Imola Red, Black Interior with Sport Package & Premium Package
620hp (516whp)
Feature in Eurotuner Dec 2007
http://www.eurotuner.com/featuredvehicles/eurp_0712_2002_bmw_m3_supercharged/index.html
1. Price: $42,500 obo
2. Mileage: 48K on chassis (10K on motor & clutch)
3. Imola Red/Black, 6-speed SMG Transmission, Pioneer AVIC-D3
4. Reason for selling: No need for a showcar
5. Location: Northern California
6. Pictures: See below
7. Are you the first owner? 2nd owner
8. Title information: Clean title on hand
9. VIN: Avaliable upon request
11. Service record: Services done myself. Oil changes every 3500 miles with Amsoil Racing 20w50 motor oil. Fresh Redline transmission fluid and Amsoil gear oil for rear differential
10. Modifications:
Engine:
BMW S54 3.2L Inline-6 stroked to 3.4L, balanced & blue printed block, custom CP pistons and rings (9.5:1 compression ratio), Eagle lightened & shaved rods, ported & polished head with 3-angle valve job, Ferrara valves & springs, Axiom Tuning titanium keepers, Custom grind camshafts, Motorsport bearings, Motorsport forged crank, Motorsport racing gasket set, Motorsport head bolts, custom built Vortech supercharger system (12 PSI @ 7800 RPM), custom front mount heat exchanger, custom air to water aftercooler painted imola red, Bosch oil pump, Bosch water pump, Bosch water pump for heat exchanger, Fluidyne Racing radiator, Motorsport low temperature thermostat, custom oil cooler with auxiliary cooling fans, Ignition Solutions plasma coils with active LEDs, iridium spark plugs, Motorsport secondary fuel rail & pump to supply 6 x RC440 secondary injectors, Supersprint headers, Supersprint race catalytic converters, Supersprint X-pipe, Supersprint SS race muffler, modified DME for ignition timing, custom Split Second AIC1 for injector control, carbon fiber intake tube, carbon fiber valve cover, carbon fiber wrapped power steering reservoir, carbon fiber DME cover, carbon fiber battery terminal cover, carbon fiber cabin air filter
Driveline:
BMW SMG II transmission, custom lightweight aluminum racing flywheel, Axiom Tuning carbon kevlar clutch, Sachs Racing pressure plate & bearing, Quaife 391 gear set with clutch pack
Brakes:
Brembo 380 x 32 mm 2-piece cross-drilled front rotors with six-piston calipers, 345 x 28 mm 2-piece cross-drilled rear rotors with four-piston calipers
Suspension:
KW Variant 2 coilovers, Rogue Engineering RSM, Eibach sway bars
Wheels/Tires:
19x8.5" (front) & 19x10" (rear) Kinesis K19R wheels powder-coated phantom black with polished lip, 255/35 ZR19 (Front) & 285/30/ ZR19 (Rear) Toyo Proxies T1-R (75/60% tread remaining)
Bodywork:
MVR carbon fiber front lip, Vorsteiner GTP red double-sided carbon fiber vented hood, carbon fiber kidney grills, carbon fiber washer grill, carbon fiber side gills, carbon fiber roundel logos, Vorsteiner carbon fiber rear diffuser, AC Schnitzer roof spoiler, AC Schnitzer trunk spoiler, driver side keyhole cover, 10% tint
Interior:
Spa electro gauge (boost & temperature), Auto Meter air / fuel gauge, custom gauge pods, carbon fiber instrument gauge, carbon fiber door handles, carbon fiber dash and console dress kit, carbon fiber e-brake handle, carbon fiber shift ****, carbon fiber SMG paddles, carbon fiber SMG dome, carbon fiber upper & lower steering wheel trim, carbon fiber steering column, carbon fiber seat outer trim, carbon fiber toolkit cover
Lighting:
Bi-xenon light system, carbon fiber headlight housings, carbon fiber lower headlight trim, Depo smoked corners, smoked side markers, smoked LED tail lights, LED license plate lights, platinum interior lighting
Audio:
Pioneer AVIC-D3 with custom double din mount and steering wheel control adapter using Harmon Kardon audio system
620hp (516whp)
10. Modifications:
Engine:
Driveline:
Brakes:
Suspension:
Wheels/Tires:
Bodywork:
Interior:
Lighting:
Audio:
