1998 Audi A4 2.0L GT35R 26k+ in after market parts
Year: 1998
Make: Audi
Model: A4
Price: $11000
Mileage: 10000
Color: Black
Location (State): CO
Transmission: Automatic
Drivetrain: 4WD & AWD
Engine: $6,300.00
-JE Forged Pistons-8.5:1
-JE Pins and Premium Ring set, End Gap set
-Carrillo Forged Rods with ARP hardware
-Forged Crankshaft
-High-Performance-German Main Bearings
-High-Performance- German Rod Bearings
-Main Bearing Girdle w/ Oil Scraper Installed
-ARP Main Bearing Studs
-Special 2.0 Liter Steel Head Gasket
-Modified Aluminum Oilpan
-Additional Deck Cooling
IPT/Detroit Transmission Specialist Built Tiptronic Transmission: $5,345.00
-Custom calibrated valve body
-Hi Energy friction plates and laser cut, surface treated 1008 steel plates.
-7 friction disk "C" clutch pack
-New one way clutches (sprags)
-Heat treated Planetary splines
-Cryogenic treated input shaft and planetaries
-Heat treated Sun shell
-Redesigned Lube system
-Revised Lock up system
-Custom High Stall Torque Conveter
Turbo etc: $7883.84
-Anodized Black Evolution Raceworks FMIC with 800hp Garret core $1,145
-GT35R $1,436.49
-Custome intake manifold by Chris Tap $300.00
-1000cc injectors $400.00
-Customer equal length exhaust manifold $1,300.00
-4 inch biag air MAF housing $275.00
-Tial 38mm wastegate $275.00
-Custom Maestro 7 tune $750.00
-Bosh 044 fuel pump $425.00
-Turbo Smart dual stage boost controller $205.99
-Fuel Race custom downpipe 3inch $299.00
-034efi/Borla exhaust 3inch $725.00
-RS4 motor mounts $237.46
-All Road transmission mounts $109.90
Suspension:$1,418.25
-H&R Ultra Low Coilovers (600front/625rear) $1328.25
-Heavy duty tie rods- $90.00
Brakes: $2,195.00
-Stoptech 332x32 floating slotted front rotors
-Stoptech 4 piston ST-40 front calipers
-Power Slott rear rotors
-Stoptech stainless break lines front and rear
-AXXIS Ultimate brake pads front and rear
Wheels and Tire: $1,768.00
-18x8 et35 OZ Superleggera Wheels $1,392.00
-225/40/18 Kumho Ecsta tires $376.00
Exterior:$1,018.70
-OEM S4 front bumper $790.58
-OEM RS4 front grill $198.17
-In-pro clear side markers $29.95
Interior: $807.74
-Greddy Turbo Timer IV $99.74
-Innovate LC1 db guage wide band$298.00
-Stewart warren boost guage $60.00
-MB Quart speakers $350.00
Just drove to Vegas for Wuste Rally and it drove like a dream.
Selling to start new project. So also willing to trade for 996 turbo tiptronic also.
Only bad: needs new flange welded on exhaust manifold to be 100% , Small crack causing small exhaust leak. Still driveable (drove home from vegas with this crack)
