FS: 2009 Lotus Exige S260 - Extremely Rare!
Old May 9, 2013 | 07:49 PM
corvettebrian's Avatar
corvettebrian is infamous around these parts
Year: 2009
Make: Lotus
Model: Exige
Price: $60000
Mileage: 14100
Color: Ardent Red
Location (State): NJ
Transmission: Manual
Drivetrain: Rear Wheel Drive
For sale is a 2009 Lotus Exige Sport 260. This is one of 27 made for North America! There are no others currently for sale. This car is in perfect condition and has never had any damage. The original Star Shield (3M clear cover) is in perfect condition. The car is 100% stock. It is truly a race car that is street legal.
EXIGE SPORT/CUP 260 HIGHLIGHTS
CHASSIS
• Lotus Designed Lightweight Structure of Epoxy Bonded
Aluminum Extrusions
• Integral Steel Seatbelt Support Structure and Lightweight
Steel Rear Sub-Frame
EXTERIOR
• Aerodynamic bodywork for increased downforce includes the following CARBON FIBER pieces: front splitter, hardtop with full length intercooler air scoop, rear tailgate, rear wing, side scoops (2), front access panels (2)
• Black mesh front brake ducts, radiator outlet and engine bay outlets
• Lotus-designed lightweight epoxy-bonded, extruded aluminum chassis
• Integral steel seat-belt support structure and lightweight steel rear sub-frame
• Hand-lay composite fiberglass body
• High intensity projection beam headlamps
• LED taillights with integral reflectors and daytime running lights
• Aluminum alloy fuel filler door
• Standard paint - Ardent Red or British Racing Green
SUSPENSION and BRAKING
• Fully independent suspension with unequal length wishbones
• Adjustable front anti-sway bar
• Adjustable Bilstein dampers with threaded spring perches and remote front reservoirs
• Damper compression and rebound are adjusted simultaneously with single ****
• Power assisted 4-wheel ventilated/cross-drilled disc brakes with 308 mm. front discs
• Lotus/AP Racing & Brembo calipers with anti-lock braking system (ABS). Uprated to four piston front calipers and uprated pads front and rear.
• Lightweight 12 spoke Forged ‘Ultra Light’ Alloy Wheels in Gun Metal Grey finish (NEW) – 7JX16 Front, 8JX17 Rear
• Yokohama Advan A048 LTS tires – 195/50-16 Front, 225/45-17 Rear
INTERIOR
• CARBON FIBER Dash Panel top and Sill Covers
• Trimmed rear bulkhead
• Alcantara FIA approved, HANS compatible sport seats with Probax anatomical padding in carbon fiber shell
• Alcantara trimmed AC surround, door panels and shifter
• Sensosoft “soft touch” dashboard paint finish
• Power windows and door locks
• Alpine stereo with in-dash CD player with I-pod connection
• Leather-trimmed Momo steering wheel
• Aluminum handbrake and gear ****
• Intermittent windshield wiper and interior trunk release
• Air conditioning, starter button, tinted glass and carpet foot mats
• DELETED: rear window and interior rear view mirror
ENGINE
• 257 horsepower supercharged and intercooled 1.8 Liter, mid-mounted 4-cylinder engine
• Multi-point fuel injection system with electronic ignition and throttle control
• Synchromesh 6-speed transaxle with lockout reverse gear
• Variable slip traction control
• Torsen (Torque-sensing) limited slip differential
• Launch Control
• Uprated clutch plate and cover to handle the increased power and torque
• Lightweight Intercooler U-Bends
• Twin oil coolers
• Accusump
• Lightweight Motorsport Battery
TRANSMISSION
• 6-Speed Close Ratio with Uprated Clutch Plate and Cover
• Lightweight Motorsport Flywheel
PERFORMANCE
• 0-60 mph 3.8 sec
• 0-100 mph 9.8 sec
• Top Speed 150 mph
• Fuel Consumption 20 City / 26 Highway
• Curb Weight 1962 to 2020lbs (US Spec depending on production inconsistencies) – fully loaded track prepped CUP 260’s have been documented to weigh approx 2020 - 2077 lbs (depending on gas and optional equip, extinguish systems, etc).
At 2076lb / 260 = 7.98 lb/HP
Old May 22, 2013 | 06:23 AM
All pm's have been replied to.
Feelgood MD
Mar 24, 2016 09:35 AM
ModBargains
Oct 13, 2015 03:43 PM
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
