FS BMW E46 M3 Race Car (new Build)
Old Jun 27, 2013 | 01:12 PM
AZ997TT's Avatar
AZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to beholdAZ997TT is a splendid one to behold
Year: 2003
Make: BMW
Model: M3
Price: $74999
Mileage: 58000
Color: Blue
Location (State): AZ
Transmission: Manual
Drivetrain: Rear Wheel Drive
FS New Build M3 Race Car
Plans have changed so I am selling my recently completed BMW M3 Race Car.
Car was built by Doug Chernis and Nick Mahalak at RaceTechnik.
Car was completed approximately 30 days ago and on its inaugural run, it ran a 20 min shake down, 15 min qualify, and 30 min Sprint Race, where it finished first in class beating the three time Arizona GTS3 Champion by a very comfortable lead.
Long story short, I started building this car for an easy/fun to drive racecar that is also economical to run and maintain. Halfway through the project, my friend decided to sell a 996 GT3 Cup that I previously owned and raced (before going to the 997 platform). Having intimately known the car and its maintenance, I repurchased the car, refreshed it, and I am going to race it in the Pirelli GT3 Cup Trophy USA West series this year.
Quite simply I can’t have three racecars so one has to go. This car is incredibly fun and very easy to drive as the almost 50/50 BMW platform inspires a lot of confidence in its ease of handling and predictability.
I have over $95,000.00 invested in this build and you can steal it for $74999
Please look at the following details of the build then feel free to contact Doug Chernis at 480 655-7475.
Car is stored approx. fifteen min from Sky Harbor Airport for those of you who wish to fly in and personally inspect or send your mechanic.
DONOR CAR
Unmolested 2003 BMW E46 M3 Topaz Blue Metallic
58,000 miles
CHASSIS
Original Sunroof cut out and replaced with factory non sunroof metal roof
Cage built by Precision Chassis Works www.precisionchassisworks.com
Rear sub-frame reinforced through body
Rear end set up for coil overs
Cage finished to match color of car
Custom rear bulkhead
INTERIOR
VAC Drivers and Passenger billet seat mounts
New Recaro SPG Hans XL drivers seat expires 2017
Recaro SPG Pro Kevlar Hans Passenger seat
Drivers seat on slider
New Schroth Drivers harness expires 2017
Team Tech mesh drivers net expires 2018
Longacre large rear view mirror
Snap Off quick release steering wheel hub
New OMP steering wheel
Motorola radio harness with IMSA plug and Push to Talk button
Safecraft 5 liter halon 1211 fire extinguisher
24-quart Cool Suit with In Dash Controls
Custom false floor and dead pedal
Heater box delete
SFI Roll Cage padding
ENGINE / DRIVE
VF Engineering cold air box with Samco inlet hose
Rouge Engineering Motor and Transmission mounts
Turner Fluidnye oil cooler
Motor has cooling system modifications
Euro style headers without cats
Meisterschaft muffler with GT Quad tip (Laguna Secca legal)
AC delete
Manual electric fan
VAC secondary air delete
Blanton BMW Motorsport 410 Ring and Pinion with Blanton plated style LSD
Rear Diff Oil Cooler with fan and pump
Turner Motor Sports solid rear diff bushings
Stock Shifter
Stock clutch
Stock ECU and map
SUSPENSION
Ground Control Racing Front and Rear Sway bars-Heavy front-light rear
TC Kline front camber plates
TC Kline rear camber links
TC Kline full double adjustable KONI racing shocks
900 lb. front / 800 lb. rear springs
All monoball suspension bushings (front and rear)
Strong Strut Billet front strut brace
AERO
APR 60’ rear wing
Front Splitter
BRAKES/WHEELS/TIRES
Hawk HP 10 front and rear pads
Stainless lines
E Brake delete
TRS Motorsport 9 ½ x 18 wheels (square set up)
TC Kline wheel studs and nuts
New 275-35-ZR18 Nitto N10 01 tires
MISC
Optima battery
Electric solenoid kill switch
Quick release front bumper
Front clear guard
TMS front and rear tow hooks
Hood pins
Xenon headlights
2013 NASA Annual Tech
NASA Logbook
FLUIDS
Castrol TWS 10-60 motor oil
Motol Gear 300 75-90 gearbox oil
Redline shockproof lightweight Rear Diff fluid
Castrol SRF brake fluid
All services complete and ready to race
Please call Race Technik at 480 655 7475
PorscheEnthusiast
Nov 13, 2015 02:23 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
