2001 M5 Carbon Black(Dinan, HRE, Brembo and more)
Year: 2001
Make: BMW
Model: M5
Price: $19500
Mileage: 117000
Color: Carbon Black
Location (State): TN
Transmission: Manual
Drivetrain: Rear Wheel Drive
VIN: WBSDE93481XXXXXX DAVIS #: N/A
Chassis Number: BZ99200 TCU MIN:
Line Make: 01 - BMW Vehicle Production Date: 2001/04
Model Year: 2001 Motor Type: S62
AG Model Code/Desc: DE93 - M5 US Platform/Engineering Series: E39
NA Model Code/Desc: 0151 - M5 Wholesale Center ID/Loc: 54600 - 01
Exterior Color Code: 416 (Carbon Black Metallic) Wholesale Date: 5/19/2001
Interior Trim Code: O5LB (Le Mans-Ble Extended Leather) Retail Center ID/Loc: 54600 - 01
MSRP: $73,045.00 Retail Date: 5/31/2001
New Vehicle Warranty Info In-Service Date: 5/31/2001
No Coverage As Of: 5/31/2005
Expiration Mileage: 50,000
Repair History
Center Loc Claim Repair Repair Repair DAVIS Mileage Defect Code/Description
ID ID Number Order Order Entry #
Number Date Date
72,360 11520115CR FAN CLUTCH PERMANENT MALFUNCTION
69,788 12230200 SIB #12-11-06 ALPINA Z8 NOT AFFECTED RECALL 06E-A03 DME REPR
60,701 62141112CR \\\\ NO LOCAL LANG DESCRIPTION FOR 58,764 65770100 SIB #65-25-03 LBL CODE 377 RECALL 03V-421 AIR BAG CU ON E39
49,677 6317004800 Front fog lights leaking
46,983 1613051400 Fuel tank leakage diagnosis module DMTL occasional malfunction
21210077MP CLUTCH DISK & PRESSURE PLATE - MAINTENANCE PLAN
6131113700 Switch (cluster) power window / door switch cluster loose
6763114800 Pump, headlight cleaning system leaking
85990093MP INSPECTION 2 (MP)
43,609 1214151100 Component, DME control unit occasional failure
6431021300 Microfilter housing broken
43,234 6121001200 Vehicle battery permanent failure
61610077MP FT WIPER RUBBER INSERT-MP
40,477 1214119600 Pulse generator, camshaft Fault code stored in diagnosis fault code memory (warning lamp on)
39,615 1214151100 Component, DME control unit occasional failure
39,360 3241014800 Vane/tandem pump/electric pump leaking
6317051200 Front fog light, bulb permanent failure
39,360 99999977CS CORE CREDITS - AUTOMATIC VIA IWS - SENATOBIA PDC
37,612 34117777MP FRONT BRAKE PADS & ROTORS - MAINTENANCE PLAN
35,999 2152034800 Clutch pipes and hoses leaking
35,999 51913391CR LIGHT ALLOY WHELLS-SHADE DIFFERENCE
35,875 85990091MP OIL SERVICE(MP)AFTER THE 1ST
32,456 1178029600 Oxygen control sensor (before catalytic converter) Fault code stored in diagnosis fault code memory
6590061400 Navigation, graphic output occasional malfunction
30,845 3352033700 Screw connection on shock absorber thrust bearing loose
3714061500 Ride-height sensor, air suspension (LF) / xenon headlight permanent malfunction
28,113 5116336500 Drink holder, front does not lock into position
6313051200 Front indicator light, bulb permanent failure
86716 1 649590 199120 6/28/2002 00/00/0000 N/A 27,662 1390019600 Fuel tank vent valve (carbon canister) Fault code stored in diagnosis fault code memory (warning lam
1613051500 Fuel tank leakage diagnosis module DMTL permanent malfunction
25,347 85990092MP INSPECTION 1 (MP)
14,377 1113024800 Oil sump gasket, bottom (V-engines) leaking
5116331300 Drink holder, front broken
6454011500 Electric auxiliary fan (pressure fan) permanent malfunction
12,813 6313051200 Front indicator light, bulb permanent failure
7,127 64360100 SIB #64-07-01 LABEL CODE 316 RECALL 01V-206
7,127 6454011500 Electric auxiliary fan (pressure fan) permanent malfunction
7,127 64330100 E39 E53 Electric auxiliary fan
2,194 6454011500 Electric auxiliary fan (pressure fan) permanent malfunction
1,369 85990088MP 1200 MI SERV -M5,Z8,S54B32 M3
Wheel setup
HRE 441R 19x9.5 Et 26 19x10.5 et 31
Falken 452 front, Naxen 3000 rear. Brand new tires.
H&R 25mm spacer front
H&R 10MM spacer rear.
Turner Motorsports studs.
Blox Forged Lugs.
Exterior Body
Exotic Tuning Carbon fiber rear diffuser
Exotic Tuning Carbon Fiber Front Lip
Exotic Tuning Fog light covers
OEM BMW Sport Aero Side Skirts
AC Schnitzer rear roof spoiler
Seibon Carbon Fiber Hood with race hood pins and Clear Bra
M3 Front hood Shocks
Matte Black Grills
Painted Eye Brows
LED rear license plate lights
Blacked out rear tail lights and front corner lights
Matte Black Vinyl roof
35% Tint
BMW motorsport Door molding badge
Dinan Chrome Rear badge
OEM 540 M sport front splitter
Yellow Day time running lights and High beams
OEM new door moldings and bumper moldings
Lights
LED Angel Eyes
Sylvania Hyper White Fog light bulbs
Interior
Anthracite Alcantara Headliner
Alcantarra suede shift boot and parking boot with M stitching
Custom Nav Radio Buttons
LED interior light bulbs
OEM rubber floor mats
Custom OEM ZHP lighted weighted shift **** with aluminum trim
OEM rear cup holders
Suspenstion
H&R Coilovers
Dinan Front and rear sway bars
Beast Power brackets
H&R spacers 15mm and 30mm
Poly urethane bushings – front control arms, trans mounts, sway bar, engine mount
OEM Shock mount bushings replaced
Breaks
Brembo Gt 4pot Big Brake Kit
Hawk Ht10 breaks rear.
H&R Stainless Steel racing brake lines with DOT 4 True blue racing brake fluid
Engine
Jailbreak Alpha-N tune (Can go back to Dinan Stage 3 Engine Management system)
Oem Clutch Fan 105k
Fuel Filter 95k
Fuel Injection Service 95k
Liqui Moly 10W-60 with Liqui Moly Oil flush 116k
Liqui Moly Ceratec 116k
A/C recharge and O rings replaced 95k
Fuel Pump 80k
Belts 95k
Coolant service 105k
Filters 95k
Mass Air Flow Sensors 80k
O2 sensors Pre cat 80k
Oem Radiator 80k
Power Steering Fluid Flush 95k
T-stat 80k
Valve Cover gaskets @95k
Vanos Hoses 95k
Spark Plugs 95k
Hose Assembly 110k
Driveline
Big Boy V3 Clutch stop
OEM Clutch replace at 100K
UUC short shift kit with shorten DSSR gear selector rod
Diff Fluid Flush @95k
Guibo Joint Bushing 98k
OEM Drive Shaft U joint bushings rear replaced 80k
Clutch Fluid replacement 109k
Exhaust
Dinan Exhaust
Super Sprint X pipe
Other Miscellaneous Items
Valentine one hardwire (V1 not included)
Updated Nav CD (Midwest)
Ventilation Fogging for allergies and bacteria
Windshield washer pump 80k
Fog Lights 111k
Update Mk3 with V 12
Price: $19500 obro
Thanks for viewing.
Elvir
2lflat4
Nov 18, 2019 05:05 PM
ModBargains
Aug 20, 2015 12:28 PM
