Mid-West Lotus Elise Got to Go!
Year: 2005
Make: Lotus
Model: Elise
Price: $23100
Mileage: 116500
Color: Storm Titanium
Location (State): MO
Transmission: Manual
Drivetrain: Rear Wheel Drive
I am LEAVING THE COUNTRY AND CAN NOT TAKE ANY CARS WITH ME.
Car is back mostly stock.
2005 Lotus Elise
Interior: Black/Carbon
Miles: 116,500
Asking Price: $23,100 As-is This is the cheapest BIN price for a running non salvage Elise in the USA right now. SO needless to say, I am pretty firm on the price.
NO TRADES AT ALL - I am LEAVING THE COUNTRY AND CAN NOT TAKE ANY CARS WITH ME.
Notes:
All Fluids current.
All scheduled maintenance done.
Newish Tires.
New Belts, Plugs, thermostat, ect
Car was looked though from the frame up last winter by me.
Run Mobil-1 10W30 full synthetic and filter every 5000 miles.
Car runs absolutely perfect, No leaks, ticks, or knocks.
Current issues:
Seats- Only has Passenger all black leather seat. Aftermarket seats were sold and do not have a drivers seat to replace it. If you plan to track the car, good time to upgrade.
Grill- No Mesh in front openings or side-scoops
Exhaust- Powder-coat flaking
Paint- Normal chips under fuel door, around trunk opening. Heat marks around exhaust
Wheels- Chips/rash on each wheel. Nothing MAJOR.
Power locks- Lock module needs replacement. Drivers door will not unlock electronically. I use manual locks. All new key-less system installed.
Mods:
Interior:
Suede Shift boot
Headliner re-done in black suede
Door Panel inserts in black suede
Kenwood Headunit w/ hands free bluetooth and USB
New JL C2 5.25" Coax dash speakers w/ trim adapter
Focal 6.5" Coax speakers in rear panel
Exterior:
Shaved front clam (Body lines, Plate mount plinith, corner lights, and flush mounted turn signals)
Professionally tinted Headlights, Turn signals, and Tail lights (Does not affect output)
De-Badged rear clam
One-off Magnaflow side exit exhaust w/ titanium wrap and chrome tip.
Rear panel delete
Mesh Boot lid(Engine cover) conversion
LED sidemarkers and plate lights
Custom one-off clear sidemarkers
Flush locking pin conversion on boot lid(Dont need ignition key to open trunk)
Tinted windows. 5% Sides and 20% rear. "Eyebrow" on front.
Permanant front and rear towhooks installed.
Toyo Proxy +4 235/45/17 in rear (500 miles). S-Drive 175/45/16 in front(1200 miles).
Black Lotus Nose badge.
HouseOfHID.com Lowbeam HID conversion
Phillips 65W Highbeam upgrade
Engine/Mechanical:
All stock internal
New Lift bolts
New Serpentine Belt (Gatorback) at 100k
New 170* Thermostat at 100k
DBA4000 front rotors, Drilled rear rotors
RC5+ Ceramic pads all around
Super Blue brake fluid
BOE All aluminum radiator
A/C Fully revamped. Resistor pack fix DONE, system re-charged.
Shifter re-enforcement mod done.
Clutch stop mod done.
Other:
BOE Re-Groved shocks (Adjustable like coilovers)
Rear subframe stripped and coated to be rust-proofed.
ATX20 Compact lightweight battery re-located to engine bay. Tender INCLUDED for long term storage.
EVAP Delete done
One-Off custom rear clam release kit installed. Can pull rear end off in 15min for engine access.
http://www.nadaguides.com/Cars/2005/...r-Coupe/Values
High Retail is $37,900, Average is $28,800
The BOE suspension is modified stock suspension. Apox 20k since modificaton.
Studio RSR
Lotus
Nov 10, 2015 07:30 PM
