AZ: 2004 Challenge Stradale
Old May 30, 2014 | 10:53 AM
azcarguy's Avatar
azcarguy is infamous around these parts
Year: 2004
Make: Ferrari
Model: Challenge Stradale
Price: $127000
Mileage: 36840
Color: Grigio Titanio
Location (State): AZ
Transmission: Automatic
Drivetrain: Rear Wheel Drive
2004 Ferrari Challenge Stradale (CS)
Vin# ZFFDU57A1401359820
Miles 36,8xx miles
Color: Grigio Titanio (3238) / Black (leather seats and dash)
Price: $127K
Modifications: Hill Engineering ball joints (front), Hill Engineering skid protectors on nose, aftermarket CS stripe installed (August 2013) and no discoloration of paint if you choose to remove it.
Factory options: Fire Extinguisher, Harnesses, Leather dash and seats, red calipers
Car comes complete with all books, manuals, keys & fobs, cover (body, not seat or steering wheel), harness pads, extinguisher, Ferrari fix-o-flat. Car has older 3M on the nose, not hood and has factory protection on brake intakes (rear) and wheel arches.
I purchased this car in May of 2013 after realizing I had sold off all my Italian cars and needed something for last year’s Italian Stampede. After having owned a lower mile CS prior to this one I decided that this was the perfect car for me to actually drive without any concern about eroding its perceived value. So, if you’re looking for a low mile garage queen this ain’t it and if you’re looking for a 100% flawless car, this ain’t it. It is however, a well cared for and mechanically stellar CS that you can drive as much as you like for as long as you choose to.
Service:
11/26/13 – oil service, header/cat replacement (L side), New 02 sensors (4)
8/7/13 – resolve oil overfill, drive belt idler adjustment, AC recharge, Updated trans mount install, installed 4 new Bridgestone RE11’s (have about 3k on them and are better than 85%)
5/28/13 – PPI done at Cavallo Motorsports*, Ball joints replaced, alignment done to factory spec
4/6/13 – Cam belt and fluid service, filter replacement, brake system flush
Prior service – was performed on annual basis at F&M in L.A., I confirmed that the clutch had been replaced and that the car had been regularly serviced.
*The PPI was conducted at my expense at Cavallo and I elected to have the ball joints replaced with Hill Engineering bits, and asked that everything that look suspect be replaced. The clutch wear was 23% and compression was as follows: Cyl 1 – 235, Cyl 2 – 240, Cyl 3 – 235, Cyl 4 – 240, Cyl 5 – 235, Cyl 6 – 240, Cyl 7 – 230, Cyl 8 – 235. SD2 readout was clean.
Items to note:
- The car has an imperfection on the passenger corner of the nose, I’m not 100% certain that it made its way through the clear bra but it may have. It is less than a pinky nail in diameter.
- The car also has a tiny chip on the fuel door and one along the leading edge of the driver’s door but both are nearly impossible to catch on pictures.
- The passenger airbag cover is a bit wavy but really not worth replacing at this point.
Link to pics here: http://azmg.smugmug.com/Cars/CS14013...4827&k=6wk2sKf
JWrightPNH
Oct 1, 2015 01:21 PM
JB GT3
Sep 24, 2015 10:01 PM
