Sponsored by: Bears Transport
Tiptronic Gearbox, Oil Leak - 997 Turbo
Old 12-19-2014, 08:35 AM
hectorturer's Avatar
hectorturer is on a distinguished road
Originally Posted by nzskater
Car is back in my hands. 5 hours of labour and $50 in parts, and the leak is no more. It was the connector as suspected. Thanks for the guidance!! Recommendation from Porsche was to drop the trans and potentially rebuild, which wouldn't have solved the issue and cost a ton. So glad I had a transmission specialist check it out. Appreciate everyone's help!
To anyone in Auckland NZ; if you have this issue, or any other with a tiptronic box, go to AutoTrans on New North Road. Highly recommended.
Glad it worked out, that's why is always good to do a research...
Old 12-20-2014, 07:59 PM
akunob's Avatar
akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !
Originally Posted by gofast
Hi,
The tip box in the 997 turbo is actually a mercedes gearbox, 722.6.
I think there is no reason it needs to be replaced unless you find copper coloured metal in the fluid.
The leak could be from the plug adapter for the cable to the TCU. Other than that look online for mercedes with the same issue and you'll probably find tons more information regarding the leak. As i said the gear box code is 722.6.
Great info that saved a fellow 6Speeder mucho $$$, rep points for sure
Old 12-21-2014, 08:35 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
I should have mentioned here as I brought it up in a few other threads. Like someone said the box is MB so Porsche is NOT going to crack it open. I think that is the big reason they like to replace it. Keep in mind this unit if pretty bulletproof overall as the SL65 AMG cars where making pretty big power on it.
SO If someone is using this thread later on in life and you have a tip. For Tranny issues you are better off going to a MB guy. Heck the trannies themselves are cheaper bought from an MB than a porsche, IE if you destroy it, and are searching for a new one, buy an MB one.
Old 06-16-2015, 03:36 AM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
Follow up to this post. Found my receipt, and googling the part description result in this video. Hopefully this helps anyone who has this issue in the future.
Old 06-16-2015, 06:11 AM
kwiksilver's Avatar
kwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond repute
Great info here for us tip drivers. Thanks.
Old 06-16-2015, 01:44 PM
TT Surgeon's Avatar
Could be the seal in the tq converter shaft, a simple pressed in seal.
Old 06-16-2015, 02:51 PM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
Great DIY video. Mine isn't leaking but if it does at least I know where to look first.
Old 09-21-2016, 02:31 AM
Nabulsi911's Avatar
Nabulsi911 is an unknown quantity at this point
Hello, I am having the same problem changed the gasket but still leaking.
What connector are you referring to that solved the problem?
Thank you.
Old 09-21-2016, 01:36 PM
nzskater's Avatar
Thank you.
This video might help:
Old 09-21-2016, 07:32 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Great info...But I must say when I watch the video I cannot help but hear Gru from Despicable Me movie ...If this guy would stop and say "Freeze Ray!", I would fall out of my chair
DC
Old 12-01-2017, 12:01 AM
AllanPac's Avatar
AllanPac is an unknown quantity at this point
what happens if you just let it be? I've changed the gasket once and still see some weeping along the edge. car is in shop to investigate dreaded coolant leak and really don't want to deal with this right now if I can help it. was thinking no big deal as long as there is no dripping/puddle on the floor
Old 12-01-2017, 12:48 PM
shadow993's Avatar
shadow993 is on a distinguished road
This is a common problem beyond the connector leak or pan gasket. It looks like a pan leak, but isn’t.
It’s a common problem on the transfer case,and dealer said it’s not repairable. Totally not true... a guy in NY sells the gaskets for $80.
The o-rings go bad or the bolts let loose inside. My car with 28k miles developed this leak. The internal bolts were hand tight. Use a medium grade locktite, and retorque after your first time around. The plate will snug up as you move around. Also, invest in a finger ratchet for those tight spots.
https://rennlist.com/forums/996-turb...ase-parts.html
Old 09-06-2018, 03:28 AM
Ironyman's Avatar
Ironyman is an unknown quantity at this point
Many thanks
#nzskater: Many thanks for the tip and guidance to the local experts. I had a very similar issue (997.1 turbo tiptronic, Porsche dealer had noted leak, said it was a repeat of a pan gasket leak). Auto Trans were on to it straight away, found gasket and connector leaks, replaced connector and made their own gasket. Also replaced the front driveline connector at very short notice after finding the old one perished. Big ups. Apparently Porsche simply does not support the MB 722.6 gearbox in their own cars! Happy to help if anyone in NZ needs guidance, and very grateful to nzskater for the earlier posts.
Old 09-08-2018, 01:47 PM
nzskater's Avatar
Great to see old posts provide assistance to people, and also to see another Turbo owner in Auckland! Let me know if you're ever up for a drive. There's a long thread under the APAC regional section of Rennlist if you're interested.
COBB Tuning
01-29-2022 09:42 AM
Mackchacha
07-09-2019 11:03 AM
PelicanParts.com
997 Turbo Vendor Classifieds
08-20-2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
PelicanParts.com
08-18-2015 03:41 PM
Quick Reply: Tiptronic Gearbox, Oil Leak - 997 Turbo
