1986 Porsche 951 944 Turbo Street Legal Track Car Forsale
Year: 1986
Make: Porsche
Model: 944
Price: $12500
Mileage: 87000
Color: maroon
Location (State): TX
Transmission: Manual
Drivetrain: Rear Wheel Drive
~82000 miles
Burgundy on Burgundy
Manual 5 speed.
Factory LSD and tranny cooler
Clutchnet Performance Clutch
Upgraded Clutch Spring Plate (~30% additional clamping force)
Ground Control Camber Plates
Full Coilovers (need to check brand/etc)
Strut brace
Sparco Racing Seats
harness bar
Schroth 4pt Harnesses (PCA legal)
Large Fire Bottle behind back seat.
A pillar gauge pod, one Oil Temp Gauge, one empty.
Turbo Boost gauge, AFM Gauge.
Extended wheel studs.
New Engine rebuild
New bearings, new seals,
Arp Rod bolts
Baffled oil sump, crank scraper,
New WP, rebuilt oil pump
LR steam vent kit in the head
New valve job, new exhaust valves, seals, seats
New AN oil lines
SS fuel lines
Catch can, 1" aos breather
New vacuum lines, idle control valve delete
Ac delete, custom turn buckle,
LR Super 75 Turbo completely rebuilt
LR SS oil feed line
rX7 oil cooler w/AN fittings and black hose
Oil temp gauge,
LR MAF kit & piggy back chip.
LR two piece cross over pipe
exhaust headers recently weld sealed
Custom exhaust header bolts
All exhaust hardware new and nord-lock washers
LR dual port waste gate
LR blow off valve.
Heater core block off plate, rerouted to WP
AC system removed from engine compartment
Cruise Control removed.
Phone dial Wheels with old Winter Tires
Early offset 911 wheels, tires are no good.
I also have a 3 piece LR cross member not on the car
Also available is a race/track short block.
joseph_number1
Jul 19, 2018 05:45 PM
