Perfect RS R32T, 2 Owners, 32k Miles, Needs nothing
Old Jul 15, 2015 | 04:06 PM
Etahgnimusnoc's Avatar
Etahgnimusnoc is infamous around these parts
Year: 2004
Make: Volkswagen
Model: R32
Price: $26000
Mileage: 32000
Color: Reflex Silver
Location (State): MD
Transmission: Manual
Drivetrain: 4WD & AWD
This is the car you have been looking for. This is not your typical R32 that has been half@$$ed. I searched for this car for a long time and the only reason I am getting rid of it is to purchase another car, otherwise I would not sell it. This is my third R32 and it pains me to sell this.
The previous owner did everything to this car and didnt skimp. If you have questions or offer please PM me, I recently had all the fluids changed and the engine mounts changed by JOSH at NLS. Oil is Motul and has been changed every 3k. All work performed by professionals no hack jobs.
The car made 484awhp.
**WILL NOT BE PARTED** **WILL NOT ENTERTAIN RETARDED OFFERS** & **NO I DO NOT NEED TO SELL THIS CAR**
The build list is below. Car needs nothing. Come take a look at the car. I am located in Maryland just outside of Baltimore.
Build List
•C2 Motorsports Stage 2+ Turbo Kit
•PT67 turbo w/ .81A/R -- Running 25PSI Boost
•SS Tubular Turbo Header
•Tial 38mm WG
•Godzilla Bypass Valve
•SS 3inch Down Pipe: V-band Equipped
•SS Short Runner Intake Manifold
•C2 R32 FMIC Kit
•24 x 8 x 3.5 Garret IC Core
•Customer Lazer Cut End Tanks
•SS IC Piping
•C2 Fuel Kit
•Bosch 580cc injectors EV14 Style w/ harnesses
•Walbro 255 LPH In-Line Fuel Pump
•C2 Custom Software -- Advanced Timing 10 degrees
•Full SS Custom 3" Exhaust by Nothing Leaves Stock
•Ceramic Coating on Turbo Hot Side, Downpipe and Exhaust Manifold
•Schimmel Performance Built Motor
•JE 8.5:1 Forged Pistons
•H -- Beam Forged Rods
•O34 Motorsport Coated Rod Bearing Set
•Raceware Head Studs
•ARP Rod Bolts
•Transmission
•Peloquin TBD
•South Bend Stg IV Clutch
•VF Motor & Dogbone mounts
•Haldex "ORANGE" Controller
•Suspension
•KW V1 Coilovers
•Ground Control Adjustable Camber Plates
•H&R Rear Sway Bar
•Yarrow Sport Rear Upper Strut Tie Bar
•Wheels/Tires & Brakes
•SSR Comps -- Anthracite
•Kumho Ecsta MX's 235/40/18
•StopTech 355mm BBK w/ SS Braided Lines
•Interior
•Sparco Pro Series 2000 Seats
•AWE Boost Gauge
•42 Draft Designs Oil Pres, Oil Temp & Volt Gauge Cluster
•AEM Wide Band -- A Pillar Gauge
•Alpine HU
•Exterior
•Cupra R Lip
•Black Grill
•Rear Wiper Delete
•Helix Projector Headlights w/ HID drop-in
•Custom Catch Can by Nothing Leaves Stock
•Snow Performance Stage 3 Water -- Methanol Injection
ID:	424007   Click image for larger version
ID:	424008   Click image for larger version
ID:	424010   Click image for larger version
Old Jul 15, 2015 | 06:59 PM
Ro_Ja Boy's Avatar
Ro_Ja Boy is infamous around these parts
Super clean. What a good value
Old Jul 16, 2015 | 05:14 AM
Thanks so much!!! Such a great car and it will be missed!
Old Jul 16, 2015 | 12:18 PM
element256's Avatar
element256 is infamous around these partselement256 is infamous around these parts
Do you have original seats?
What's the pump gas HP?
Old Jul 16, 2015 | 12:49 PM
Thanks for the questions Element!
No on the seats (the original owner sold them)
I do not have an exact number on pump only as the dyno numbers were 93+meth. I would imagine probably around mid to low 400s, but its still quick ( :
Also I have a bunch of extra parts that come with the car. Pads, Car cover, OEM LSD, OEM headlights, etc...
Let me know if you have any other questions.
-Scott
Old Jul 27, 2015 | 02:30 PM
Monday Bump
COBB Tuning
Jan 1, 2025 09:02 AM
SharkyShark20
Sep 19, 2015 09:54 PM
turbotuner20v
Sep 11, 2015 12:02 PM
Zero911
Aug 24, 2015 06:51 PM
Glasig
Aug 23, 2015 03:35 PM
