Need to replace 2011 Panamera Turbo Brakes
Was at Porsche Oakville for an oil change - my brakes are almost gone. I was given a quote for about $5000 for the front and rear...
Few questions:
1. Reasonable or not, if not - any alternatives?
2. If I go somewhere else, and say get Brembo brakes installed, does this void any warranty?
Thanks.
Few questions:
Thanks.
Wtf ? 5K for steel oem brakes ? For that price get the aftermarket brembo and repaint the caliper . Usually aftermarket stuff void only the warrenty for that parts , so warranty wont take care if your brembo brakes , in which in the end must be coveres from tunning company
Parts alone:
FRONT Brake Pads
Without Ceramic Brakes Part# 97035194904 $322.48 With Ceramic Brakes Part# 97035194803 $340.90
REAR Brake Pads
Without Ceramic Brakes Part# 97035294904 $227.62 With Ceramic Brakes Part# 97035294703 $275.53
FRONT Rotors
Without Ceramic Brakes Part# 97035140600 $759.82 With Ceramic Brakes Part# 97035140832 $4499.92
REAR Rotors
Without Ceramic Brakes Part# 97035240600 $290.66 With Ceramic Brakes Part# 99735203201 $4036.35
Labor: $160/hr
Now you know what to do. Get parts and go to INDY shop.
FRONT Brake Pads
REAR Brake Pads
FRONT Rotors
REAR Rotors
Labor: $160/hr
By the $5000 price, I assume that your rotors are worn out, not just brake pads.
So the real question we have for you is: How many miles on your car that your rotors (or calipers) are worn out?
But maybe it's not the rotors if you're talking about if you say your thinking of replacing your brakes with Brembos. I would guess you're not talking about replacing your rotors with Brembos. Do you instead mean that there is a problem with your calipers?
By the way, Porsche does not have their own brake factory. Are they not already Brembos on your car?
My understanding is that P dealers recommend changing the rotors every time you change the pads. Most indy's would suggest evaluating whether the pads and rotors need replacing independently from each other.
That price is roughly appropriate if you're changing both pads and rotors all the way round, although you could probably save $800 or so if you bought the parts yourself and had an indy do the work.
Pads alone should be more in the range of $500-800 total depending on whether you replace with OEM or replacement pads (e.g., EBC reds).
I'm at 42k miles on my PTT and haven't had to replace either pads or rotors yet, although the pads are getting close. Drive in sports + mode and the engine does most of the braking.
Hope that helps.
Hope that helps.
That would be ridiculous.
I should probably add some more info.
I bought the car with about 46K last November - from a non-porsche dealer in Ottawa, (swapped my 650i) who picked up from the US a year prior. To my surprise, he never had the vehicle serviced, so I had to get this done as soon I purchased the vehicle. The rotors and pads have to be replaced.
There is 57k on the vehicle now - with (looking at the quote)
"Front brakes at 4mm. Rear brakes @5mm."
"Front and Rear Tires @ 7mm"
For the front and rear rotor set + front brake and rear break pad set would cost about $2200 USD from Suncoast. I can't image the labour for replacing all 4 would amount to another $3k in labour at the dealership.
Pardon my ignorance...Just wanted to gauge other members experience. I am a bit ignorant when it comes to cars...I only fix humans, at least try to
Thanks for everyone's input.
Much appreciated.
Much appreciated.
$5000 for brakes?!
Go to a local independent shop and see what they will charge you. You can buy good pads online for about $400 for all 4 corners. You most likely don't need rotors.
I love hawk pads. Google them and see what they cost.
The calipers on the Panamera are a different design from the sport cars. They are similar to the Cayenne. Looking at the EBC fitting guide, the front pads are the same as the 2010+ Cayenne, but the rear pads are different.
So i asked my SA recently about this - he said they try to just replace pads but the rotors often get deep grooves in them, so then you have to replace the rotors to extend pad life - pads and rotors around 4K
Few questions:
Thanks.
Few questions:
Thanks.
Anyone recommend a specific set of rotors and pads? I might switch over to Brembo but trying to figure out if I should do drilled or slotted rotors. I also have the silver calipers (4S) and really want to swap them out for red. Although I don't know I want to spend 8K+ on the full Brembo brake package. I just had to drop some cash on new engine for my car (camshaft broke and extended warranty covered a little over 14K on a 22K bill).
